    Nespi4 Shutdown Script Help
    nespi4clean shutdownhelpraspberry pi 4
    1 Posts 1 Posters 304 Views
      rtarroyo
      Re: NesPi 4 Hiding Shutdown Text
      There was already an unanswered post about this, but is there a way to make the terminal not show up when shutting down/rebooting the Pi with the Nespi4 script?
      import RPi.GPIO as GPIO
      import os
      import time
      from multiprocessing import Process
      #initialize pins
      powerPin = 3 #pin 5
      ledPin = 14 #TXD
      resetPin = 2 #pin 13
      powerenPin = 4 #pin 5
      #initialize GPIO settings
      def init():
      	GPIO.setmode(GPIO.BCM)
      	GPIO.setup(powerPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      	GPIO.setup(resetPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      	GPIO.setup(ledPin, GPIO.OUT)
      	GPIO.output(ledPin, GPIO.HIGH)
      	GPIO.setup(powerenPin, GPIO.OUT)
      	GPIO.output(powerenPin, GPIO.HIGH)
      	GPIO.setwarnings(False)
      #waits for user to hold button up to 1 second before issuing poweroff command
      def poweroff():
      	while True:
      		#self.assertEqual(GPIO.input(powerPin), GPIO.LOW)
      		GPIO.wait_for_edge(powerPin, GPIO.FALLING)
      		os.system("sudo killall emulationstation")
      		os.system("sudo killall emulationstatio") #RetroPie 4.6
      		os.system("sudo sleep 5s")
      		os.system("sudo shutdown -r now")
      #blinks the LED to signal button being pushed
      def ledBlink():
      	while True:
      		start = time.time()
      		while GPIO.input(powerPin) == GPIO.LOW:
      			GPIO.output(ledPin, GPIO.LOW)
      			time.sleep(0.2)
      			time.sleep(0.2)
      #resets the pi
      def reset():
      	while True:
      		#self.assertEqual(GPIO.input(resetPin), GPIO.LOW)
      		GPIO.wait_for_edge(resetPin, GPIO.FALLING)
      if __name__ == "__main__":
      	init()
      	#create a multiprocessing.Process instance for each function to enable parallelism
      	powerProcess = Process(target = poweroff)
      	powerProcess.start()
      	ledProcess = Process(target = ledBlink)
      	ledProcess.start()
      	resetProcess = Process(target = reset)
      	resetProcess.start()
      	powerProcess.join()
      	ledProcess.join()
      	resetProcess.join()
      	GPIO.cleanup()
      The code seems simple enough, but Im not at all good at coding.
      I tried a few changes with no luck.
