    dark layer on screen except top left corner (ppsspp/lr-ppsspp)
    ppssppdark layerlr-ppsspp
    13 Posts 8 Posters 2.4k Views
    • W
      weird_ed
      Pi Model or other hardware: 4B
      Power Supply used: original Pi Powersupply
      RetroPie Version Used : v4.7.1
      USB Devices connected: USB Hub (Belkin USB 2.0 4 Port Powered Hub)
      Controller used: DragonRise Inc. Generic USB Joystick
      Emulator: PPSSPP / lr-ppsspp
      Hi there.
      I am testing around with ppsspp and it seems to work well. However while trying to play assassins creed it seems as if there is a kind of layer on the screen which makes it dark/grey/blurry. Only the top left quarter of the screen seems to be normal. (as shown in the picture below)
      This problem shows up using either PPSSPP or the libreto version(lr-ppsspp) as soon the intro scene has ended and reaching th emain menu so I assume this could be an issue concerning the rom and not the emulator?
      Maybe someone stumbled over this too.. Any suggestions are appreciated.
      thanks in advance
        djax9
        Any luck with this? I cannot seem to find anyone else with this problem except you.
        I tried just about every array of settings in PPSSPP and lr as well... no luck.
        Weird how its only in this game... I also downloaded 3 different versions and got the same square.
          philcsf
          Just saw this on my own system as well. Looking at PPSSPP's automated testing, it definitely seems to be a regression on their end, so I'll raise something on their forum/github.
          https://report.ppsspp.org/game/ULUS10455_1.00
            Bedu
            anyone figured out ? I got the same issue on the same game, also noticed the same dark layer in Spider-Man: web of shadows when i start the mission 2....
            • W
              weird_ed
              still no ideas on this issue?
              recently I found the same problem when trying to play "indiana jones - the staff of kings" same system, same emulators, same problem...
              • DigrizD
                Digriz
                I had this in standalone ppsspp then upgraded it to the lastest source and it went away. Try updating ppsspp from source.
                BW
                Raspberry Pi 4 o/c to 2MHz
                Pizen Case & Ice Tower
                Samsung T5 External SSD (500GB)
                Official Pi4 Power Supply
                RetroPie 4.7.1 image built with Raspberry Pi Imager on 512Gb SanDisk Extreme Pro microSDXC card
                2x DragonRise Controllers
                2x 8BitDo SN30Pro+
                  bleau11
                  I for me the only thing that fixed it was to overclock my pi and use another version of the game I dont wich one particularly fixed it but this what I've done to fix I know this post is quite old but it's the only post about this issue that I've found so I'm posting for anybody that didn't fixed this issue
                    Bedu
                    @bleau11 what s your overclocking specs? I tried to uptade to the latest source version, change game version and still no sorted it out...
                    DigrizD 1 Reply Last reply Reply Quote 0
                    • DigrizD
                      Digriz @Bedu
                      @bedu here you go
                      over_voltage=6
                      arm_freq=2000
                      gpu_freq=750
                      with gpu memory set to 512.
                      Just tried again, and it's still working fine with the latest source for me.
                      2x 8BitDo SN30Pro+
                        Bedu @Digriz
                        @digriz Thanks mate! i just tried your overclocking specs with the latest source version (different game version as well) and nothing changed...i tried everything and i don't know what else to do to get rid of that issue.
                        • quicksilverQ
                          quicksilver
                          Overclocking can slightly improve FPS but it will not make emulation more accurate. In fact that gpu mem setting is completely unnecessary on a pi 4 in regards to emulation as the pi 4 dynamically allocates memory to the gpu. That setting is really mainly used for the H264 video codec and the camera.
                          • windgW
                            windg
                            I am using the ppsspp v1.10.2 and i dont have this issue. Is older version but im still using it because the games running faster that the new versions.
                            I have uploaded it if you want to test it : https://easyupload.io/x8dr4g
                              Bedu
                              @windg thanks man, i will check it later...I assume that the issue has to do something with the raspberry pi GPU, cos having the latest source, latest PPSSPP version, overclocked...could it be a GPU malfunction?
