    Couldn't configure X5500 audio card
    audio sound
    8 Posts 2 Posters 739 Views
      stiakooo
      Re: Volume control not working HiFiBerry MINI-AMP + Retropi 4.4 + RaspberryPi 3B - lvl0: Volume control::inint() - Failed to find mixer elements
      Hello!
      I am building my own arcade machine. I decided that I want a hardware potentiometer to control the volume. After a quick research I found that Geekworm X5500 should do the job. So I purchased that device and put it on top of my Raspberry Pi 4B. Unfortunately I couldn't properly configure the sound in Emulation station. I don't have sound in the games. I also don't have navigation sounds. I've read the retropie documentation related to sound issues but I couldn't find a solution.
      First I tried all the possible combinations in ES Sound settings.
      Then I made the following changes in config.txt:
      #dtparam=audio=on
      dtparam=audio=off
      dtoverlay=hifiberry-dac
      Based on the manufacturer wiki I should use hifiberry-dac for dtoverlay. More info here:
      https://raspberrypiwiki.com/X450/X5500_Software_Configuration
      If I run aplay -L I have the following list:
      null
           Discard all samples (playback) or generate zero samples (capture)
      default
      output
      sysdefault:CARD=sndrpihifiberry
           snd_rpi_hifiberry_dac, HifiBerry DAC HiFi pcm5102a-hifi-0
           Default Audio Device
      dmix:CARD=sndrpihifiberry,DEV=0
           Direct sample mixing device
      dsnoop:CARD=sndrpihifiberry,DEV=0
           Direct sample snooping device
      hw:CARD=sndrpihifiberry,DEV=0
           Direct hardware device without any conversions
      plughw:CARD=sndrpihifiberry,DEV=0
           Hardware device with all software conversions
      As you can see above, I don't have a default card. However It seems I have sysdefault.
      And If I run amixer scontrols -D default I receive:
      amixer: Mixer attach default error: No such file or directory
      And here is something interesting. If I run amixer scontrols -D sysdefault It doesn't return anything! No error this time but also no list of devices (mixers). So it seems there is a sound card but there aren't any audio devices (mixers) on it.
      Then I decided to go back in ES and I selected sysdefault in ES sound settings and I tried with all of the listed possibilities for Audio Device without any success.
      Additionally I tried aplay -l and it gives me the following:
      card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
           Subdevices: 1/1
           Subdevice #0: subdevice #0
      If I run amixer scontrols -D sndrpihifiberry I receive the following error:
      ALSA lib control.c:1375:(snd_ctl_open_noupdate) Invalid CTL sndrpihifiberry
      amixer: Mixer attach sndrpihifiberry error: No such file or directory
      And finally i made the speaker-test. if run speaker-test -D sndrpihifiberry -t wav -l 20 & I receive:
      Playback open error: -2,No such file or directory
      But if I run speaker-test -D sysdefault -t wav -l 20 & the test is successful and I can hear a voice calling "Front Left" 20 times with the corresponding logs in the terminal. Which means the audio card itself is working correctly but I can not properly configure it in EmulationStation!
      Sorry for the very long description but I wanted to mention everything I tried.
      Thank you in advance!
        mitu Global Moderator @stiakooo
        @stiakooo said in Couldn't configure X5500 audio card:
        What does
        amixer -c 0 scontrols
        or just
        amixer scontrols
        show ? It should be the name of the (simple) mixer attached to the card.
          stiakooo @mitu
          @mitu Thank you for your post!
          The first command returns nothing:
          And just amixer scontrols returns an error:
          amixer scontrols
            @stiakooo Do you have anything in $HOME/.asoundrc ?
            Is alsamixer working ?
              stiakooo @mitu
              cat $HOME/.asoundrc
              pcm.!default {
                   type asym
                   playback.pcm {
                        type plug
                        slave.pcm "output"
                   capture.pcm {
                        type plug
                        slave.pcm "input"
              pcm.output {
                   type hw
                   card 1
              ctl.!default {
                   type hw
                   card 1
              Runnung alsamixer without any parameters it returns error:
              alsamixer
              cannot open mixer: No such file or directory
              If I try with sysdefault
              alsamixer -D sysdefault
              I have the alsamixer UI but there is only the message "This sound device does not have any controls." in the center of the screen.
                @stiakooo Remove your $HOME/.asoundrc and try again to see if you still get an error with alsamixer.
                  stiakooo @mitu
                  @mitu Thanks a lot for all the advices! I finally found a solution that is working for me.
                  Just deleting .asoundrc wasn't enough. What is important in my case is to enable the softvol ALSA plugin.
                  To summarise what I needed in order to have sound in the games and also in the EmulationStation menu for my Geekworm X5500 ( I guess it should be the same also for X450).
                  1. /boot/config.txt
                  # dtparam=audio=on
                  dtparam=audio=off
                  1. /home/pi/.asoundrc
                    You need to enable softvol ALSA plugin. For more info visit https://alsa.opensrc.org/Softvol
                    Delete everything and put the following:
                  pcm.newdevice {
                      type softvol
                      slave.pcm "default"
                      control.name "Softmaster"
                      control.card  0
                  1. /home/pi/.emulationstation/es_settings.cfg
                  <string name="AudioCard" value="default" />
                  <string name="AudioDevice" value="Softmaster" />
                  Note: The volume control inside EmulationStation is useless after those changes. The only way to control the volume is using the hardware potentiometer (which is exactly what I need).
                  Thanks again!
                    So, in other words, the card doesn't have a software volume control and you had to add a fake one to keep ES (or other ALSA based mixers) happy. That doesn't seem too practical if your Pi is not easily accessible.
                    Glad you got this sorted out, it's a good use case to have in mind.
