    Rasp Pi 4 8GB will not boot from Retropie SD card
    start4
    27 Posts 2 Posters 7.4k Views
    • Honda Z50MH
      Honda Z50M @mitu
      @mitu Done that typed both Sudo apt-get and sudo apt update but just get a timeout after 15secs
      • Honda Z50MH
        Honda Z50M @mitu
        • Honda Z50MH
          Honda Z50M @mitu
            Looks like WinSCP doesn't like how long it takes for the command to complete. Use Putty instead to login and run the upgrade commands and - after the upgrade is finished - reboot by entering sudo reboot.
            Honda Z50MH 3 Replies Last reply Reply Quote 0
            • Honda Z50MH
              Honda Z50M @mitu
              @mitu ok with putty get the normal pi terminal, do I need to do anything to allow the pi internet connection through laptop?
              Looks like it has no internet access lots of failures
              • Honda Z50MH
                Honda Z50M @mitu
                @mitu got connected to wifi via config seems to be updating watch this space
                • Honda Z50MH
                  Honda Z50M @mitu
                  @mitu Finally got it working ok with your help (THANK YOU), full upgrade using Putty worked although my laptop crashed and corrupted the SD card at around 80% of update and had to reflash it and start all over again.
                  But copying the two files across, then updating via putty worked in short.
                  Thanks,
                  Tom
