    2.3k Posts 37 Posters 8.2m Views
    • FollyF
      Folly @DTEAM
      @dteam
      Damn, that's nice.
      Tonight I had the idea to only let the the retroarch-overlays create when there is a Background.png available.
      Then we don't get configs we can't use.
      This way I can keep all game names in the array's
      And then I don't have to remove the ones that don't use backgrounds.
      Btw. we can also use it now for checking on which games we have to work on.
      How does that sound ?
      Edit :
      I just added an if function in my script, and it's working.
      (I do not have the possibility right now to add it on github, I will do that later)
      • DTEAMD
        DTEAM @Folly
        @folly
        For overlays, it's frustrating on my end for Lr-mess-cmd. It always points to / opt / retropie / configs / all / retroarch / overlay and not to your directories. I have to do it manually. I am looking to see if I missed something during the installation.
        I'll re-install the all thing properly.
        • FollyF
          Folly @DTEAM
          @dteam
          Indeed, I that is really frustrating.
          Really, I have no idea what is causing this.
          Have a look at /home/pi/.config/retroarch/retroarch.cfg
          I remember I had some trouble adding options in the retroarch.cfg in /opt/retropie/configs/all.
          So I did it in /home/pi/.config/retroarch/retroarch.cfg .
          Perhaps you have options in there that's causing it.
          You could rename it, to see what happens.
          You can alway's rename it back.
          I could also change the script, so all background files come in that directory.
          Would that be a solution ?
          • DTEAMD
            DTEAM @Folly
            @folly
            I could change the script, so all background files come in that directory.
            It could be good, because like that, you will use the default Retroarch overlay folder for Retropie.
            I'm gonna try that
            • FollyF
              Folly @DTEAM
              @folly
              Ok, I will make a commit when I can.
              Then I will remove the subdirectory's also.
              All overlays are saved in /opt/retropie/configs/all/retroarch/overlay
              Basically it will look like the artwork directory but then containing .cfg and .png.
              I was able to do a commit on github.
              I did the change without testing, but should work. (did test : OK)
              If you comment part 2 and 3 in the script it will not download all again.
              I think you know how to do that.
              You have to manually remove /home/pi/RetroPie/overlays.
              • FollyF
                Folly @DTEAM
                @dteam
                I have rewritten the readme on the github page :
                https://github.com/FollyMaddy/RetroPie-Share/blob/main/00-scripts-00/readme.md
                I also reorganized the whole repository to get a better oversight.
                Improved ?
                • DTEAMD
                  DTEAM @Folly
                  I reinstalled everything and now all overlays working fine with retroarch. Great job.
                  Improved ?
                  Good "readme" on github. Everythings are easy to understand. It's fu%?$ng nice!
                  • FollyF
                    Folly @DTEAM
                    @dteam
                    That is really great to hear.
                    We have done an incredible job here !!!
                    I still have some ideas of implementing downloads into the module-scripts.
                    So if we want, we can try that part in the future. :-)
                    • DTEAMD
                      DTEAM @Folly
                      @folly
                      Just a reminder
                      for :
                      bash $version ablmini # creates cmd script for all_in1 # bootable
                      bash $version alnattck # creates cmd script for classich # bootable
                      bash $version gnw_ball # creates cmd script for gameandwatch # bootable
                      bash $version jak_batm # creates cmd script for jakks # bootable
                      bash $version kgradius # creates cmd script for konamih # bootable
                      bash $version taddams # creates cmd script for tigerh # bootable
                      bash $version rzbatfor # creates cmd script for tigerrz # bootable
                      and more ...
                      you can get gamelist.xml files here
                      and images, marquees and videos for those gamelist.xml files , here
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        If I have some time, I can try to add it in the get...script.
                        • FollyF
                          Folly @DTEAM
                          @dteam
                          I had a quick look at the gamelist files.
                          It's quite simple now to download them all in the correct place with these commands ( this can be added to the get script ) :
                          wget -nv -O /tmp/gdrivedl.py https://raw.githubusercontent.com/matthuisman/gdrivedl/master/gdrivedl.py
                          python /tmp/gdrivedl.py https://drive.google.com/drive/folders/1f_jXMG0XMBdyOOBpz8CHM6AFj9vC1R6m -P /opt/retropie/configs/all/emulationstation/gamelists
                          rm /tmp/gdrivedl.py
                          This will not only download the handhelds but also the others.
                          Is this a problem ?
                          One problem I have is, I have .zip files.
                          Gamelist files that only have .7z files in them, will not work for someone who has .zip files.
                          Could you add them on the googles drive ?
                          You can add them simply by using these commands once (!) on a gamelist and then putting them on google drive again.
                          ( make a backup of the file before you use this ! )
                          Go to the directory of the specific gamelist and do :
                          (tested and should work)
                          sed -i 's/..gameList.//g' gamelist.xml
                          cat gamelist.xml | grep -v ?xml | grep -v gameList | sed 's/\.7z/\.zip/' >> gamelist.xml
                          echo "</gameList>" >> gamelist.xml
                          Explanation :
                          • sed removes the last line because otherwise we have "</gameList>" end halfway after adding the ".zip" files
                          • cat shows (pipes it now to the next commands) the file in the terminal, except the lines containing ?xml and gameList using grep
                          • sed looks for ".7z" entry's and replaces them with ".zip
                          • ">> gamelist.xml" will write and add all lines, that went trough sed and grep, to the same gamelist file
                          • so all game entry's double, keeping the originals and adding the ones for ".zip"
                          • echo makes sure the file gets the last line "</gameList>" end again
                          Make sure you do this only once to the file, otherwise the game entry's will triple etc...
                          ps.
                          You can also do this with gamelist that only have ".zip" files, adding ".7z" :
                          cat gamelist.xml | grep -v ?xml | grep -v gameList | sed 's/\.zip/\.7z/' >> gamelist.xml
                          • DTEAMD
                            DTEAM @Folly
                            @folly
                            Is this a problem ?
                            No problem, but most gamelist.xml files are made for mess/mame romset (excepted pockstat and svmu). It doesn't work if people use No Intro or TOSEC romsets.
                            I'll do the modification for 7z/zip this week.
                            Regards
                            • DTEAMD
                              DTEAM @DTEAM
                              @dteam
                              sed fonction only works in Linux. Doesn't work in PowerShell or as a .bat
                              Show me an example of that and I'll do It manually with the basic search and replace tool.
                              Starting example :
                              <path>/home/pi/RetroPie/roms/tigerh/taddams.7z</path>
                              new edit
                              I'll do it directly on the Pi
                              • FollyF
                                Folly @DTEAM
                                @dteam
                                I have added them all in 00-gamelists-00 :
                                So you can copy them to the googledrive.
                                • DTEAMD
                                  DTEAM @Folly
                                  @folly
                                  The transfer with your files on Google Drive is done. Thanks for the conversion/addition . Sorry for that.
                                  • FollyF
                                    Folly @DTEAM
                                    @folly
                                    The transfer with your files on Google Drive is done. Thanks for the conversion. Sorry for that.
                                    No problem.
                                    It was a fast conversion.
                                    • DTEAMD
                                      DTEAM @Folly
                                      @folly
                                      Do you know if anyone started creating these systems in official Retropie themes?
                                      It's a kind of request if an artist read this šŸ˜‰
                                      • FollyF
                                        Folly @DTEAM
                                        @dteam
                                        I don't know.
                                        We have to take a look.
                                        BTW. Did you make a backup of your old gamelists if something went wrong ?
                                        • DTEAMD
                                          DTEAM @Folly
                                          yes
                                          • FollyF
                                            Folly @DTEAM
                                            yes
                                            super !
