    2.3k Posts 37 Posters 9.1m Views
      bbilford83
      OK folks, I added one more to the google drive, vsmile. You can use retroscape for it but only a small portion of the games properly scraped, and even those were missing a lot of info, so I thought you might want this one in the repository. No worries if not. I'll return to Jakks now, I think that's it for me and software list.
      Edit: Now I am done with Jakks too, I added a folder with both versions of the gamelist but no art folder because I didn't replace any art for that one.
      FollyF 1 Reply Last reply Reply Quote 2
      • FollyF
        Folly @bbilford83
        @bbilford83
        Nice,
        We will have a look at it.
        Edit :
        When I was busy with your jakks gamelist I discovered that there is a mistake in my script.
        The index file with the supported jakks games was faulty.
        I will fix that in the new release.
        So after the fix I was able to check if all drivers were added.
        I found that your gamelist misses 2 entries :
        • jak_dwmno
        • jak_sithp
        The descriptions are probably the same as :
        • jak_dwmn
        • jak_sith
        Can you add these too ?
        I like the new descriptions for the jakks I think the gamelist should be added if @DTEAM agrees.
          bbilford83 @Folly
          • jak_dwmno
          • jak_sithp
          • jak_dwmn
          • jak_sith
          I'm happy to but I am a little confused, are these clones? I don't remember if I had them and tried them or not but if they are the same gameplay I may have assumed they were duplicates somehow and left them off.
          • FollyF
            Folly @bbilford83
            @bbilford83
            I had a look and these drivers and the descriptions from mame are :
            • Driver jak_dwmn (Dreamworks Movie Night (JAKKS Pacific TV Game, Oct 18 2006, prototype)):
            • Driver jak_dwmno (Dreamworks Movie Night (JAKKS Pacific TV Game, Apr 24 2006, test program)):
            • Driver jak_sith (Star Wars - Revenge of the Sith (JAKKS Pacific TV Game, Game-Key Ready)):
            • Driver jak_sithp (Star Wars - Revenge of the Sith (JAKKS Pacific TV Game, Game-Key Ready, prototype)):
            Seem that they are indeed somewhat obsolete.
            However I can't filter them out so it's probably best to include them.
              bbilford83 @Folly
              @Folly I am happy to put in duplicates but do you think it makes more sense to leave them out? Or I guess I can say these are outdated/earlier versions of the same games? For me I wouldn't want a prototype if the final is available but I understand some might.
              FYI I moved onto the All_in1 and I am so far not very optimistic. There's soooooo little info out there about these compared to Jakks or the Classic Handhelds, I'm not sure I could make a decent gamelist. And honestly at least so far they've all just been bootleg compilations, so I can see why there wouldn't be tons of info out there about them. I may at the end keep only ones that aren't bootleg compilations and that I can find information about, but I would assume you wouldn't want my gamelist then and would prefer the generic-if-barebones one you have up there now?
              • FollyF
                Folly @bbilford83
                Thanks.
                I think we should keep them in.
                I like the idea that the collection is most complete and it will save me time to filter it out (if I should be able to).
                I agree,
                All_in1 is too difficult to describe all.
                In my perspective the generic-if-barbones will do.
                Just an idea :
                It's possible to add your gdrive to the script just like with the one of DTEAM so one could choose between one and the other.
                A sort of alternative with a few differences and some other system.
                For me it would make sense to put it in as a gdrive with "wip - work in progress" predefined gamelists.
                So in time stuff that goes to the grdrive of DTEAM can be deleted on your gdrive (if you want) and stuff that won't go the gdrive of DTEAM is an addon for the users.
                Do you like that idea ?
                B DTEAMD 2 Replies Last reply Reply Quote 0
                  bbilford83 @Folly
                  @Folly That would be fine with me, whatever you think makes sense. I think I am pretty much done with the gamelists now actually... I was trying to give Pico and a couple others a shot but they're not really workable for a variety of reasons. So you are welcome to use them however you see fit, I hope they're helpful!
                  • DTEAMD
                    DTEAM @Folly
                    Just an idea :
                    I'll update my drive with @bbilford83 additions (comments and upgrades) , I'll try to do that next week.
                    Does somebody is able to run UBOAT from MAME 0.259. On my side, it won't load.
                    Bandai U-Boat [hap, Sean Riddle, eggs] ROM name= UBOAT
                    FollyF DTEAMD 2 Replies Last reply Reply Quote 0
                    • FollyF
                      Folly @DTEAM
                      It does load (on my x64 vm) however the controls do not seem to work correctly for P2. ( not tested on my pi yet )
                      For player 2 left and right are flipped. (key d and key g)
                      I think the destroyer is above and the uboat below.
                      The destroyer shoots from top to bottom and the uboat seems to shoot in the upper screen from left to right.
                      Perhaps we have to look at the manual.
                      How did you download it, manual from mame-merged or did you use my restricted option ?
                      Edit :
                      I found the manual on archive (manuals-handheld-games-Bandai-UBoat)
                      The flipped player2 controls make some sense as it looks there are 2 screens in oposite direction.
                      • DTEAMD
                        DTEAM @Folly
                        mame-basename-autoframeskip = "/opt/retropie/emulators/mame/mame -rompath /home/pi/RetroPie/BIOS/mame\;/home/pi/RetroPie/roms/classich -v -c -ui_active -statename classich/%BASENAME% -autoframeskip   %BASENAME%"
                        • FollyF
                          Folly @DTEAM
                          @DTEAM
                          That runcommand works for me too.
                          My question was a different one and is your rom ok ?
                          Is your mame version on 259 now, can you check ?
                          • DTEAMD
                            DTEAM @Folly
                            @Folly
                            Mame-merged
                            • FollyF
                              Folly @DTEAM
                              @DTEAM
                              Just curious.
                              Do you do that always manually ?
                              • DTEAMD
                                DTEAM @Folly
                                @Folly
                                Most of the time yes , but not all the time.
                                • FollyF
                                  Folly @DTEAM
                                  @DTEAM
                                  Ok, know enough
                                  Not sure why it doesn't work will check on my pi later.
                                  Did you check your log ?
                                  • DTEAMD
                                    DTEAM @Folly
                                    @Folly
                                    Not yet, I'll do it tomorrow
                                    • FollyF
                                      Folly @DTEAM
                                      @DTEAM
                                      FYI, It works on my pi.
                                        bbilford83 @Folly
                                        I assume it should work the same as the art currently downloaded by the script - i.e. move the zip to bios/mame/artwork and it will automatically load?
                                        Yes, but as far as I can see for mame standalone it will be :
                                        roms/mame/artwork
                                        For lr-mame / lr-mess I think it would be :
                                        BIOS/mame/artwork
                                        @Folly, I decided to give this one more try and I made .zip artwork files for two more games based on the ones you did. I am not sure they will work - I was really struggling along in Gimp - but then when I went to test them none of them seem to work anyways. Nothing automatically loads when I add the artwork to either folder, and I think it is because these are software list roms rather than "mainline" mame roms, if that makes sense. Game and watch, Tiger, Konami, and ClassicH (all of which I can use the art) are all "normal" mame roms, so I think that is why it is different. But everything I can find online isn't helping me figure out how to make it work. Wondering if you have any ideas?
                                        I am not confident my artwork will work anyway but I will give it a shot if I can :).
                                        • FollyF
                                          Folly @bbilford83
                                          @bbilford83
                                          I assume you are talking about the microsvn artwork.
                                          Did you try mine first without editing ?
                                          Can you share it in your folder with the pictures ?
                                          Then I can take a look.
                                            bbilford83 @Folly
                                            @Folly Yes, sorry, the microvsn artwork. I tested yours before the others I made, mame isn't picking up any of them. I goofed around trying other ideas (I thought maybe a subfolder first with "microvsn" but no). I tried a bunch of searches to see how the art would differ for software list roms but didn't find anything helpful. But it makes sense that it wouldn't just work, because I assume some of the rom filenames in software list systems are the same (as each other and as some arcade roms).
                                            I added yours + the two I made to a subfolder in my gmail folder you linked. I stopped trying to make more because I'm super slow and don't know if they're going to work... I'm not rearranging anything in the layout file and just trying to place the correct new artwork over the old ones in the one you made.
                                            Edit: Truth is I'm not sure it matters anyway, I can't for the life of me get the games to control/be playable. I mapped all 12 buttons and still can't seem to get anything to play, it seems to me like the paddle at the bottom just isn't moving even though it's registering the input properly in mame. So I may be giving up on the system even if we get the art working :).
