    2.3k Posts 37 Posters 9.0m Views
      bbilford83 @bbilford83
      @duglor I think it was system-wide, sorry for the false hope on that. Though is there a reason to have the sensitivity higher for any other games? It seems way too high by default across the board to me.
      Unrelated, I am testing out your overlays now, thank you so much for sharing them. Only one I tested so far though is connect four and after following your scaling instructions I don't think it's working for me... I can't see the piece on the top to know where I'm putting things and when they land they are going too low. See following picture. Are you getting better results or was this just how it was for you too?
      • FollyF
        Folly @duglor
        @duglor said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
        @Folly
        https://drive.google.com/drive/folders/1TV2uGzbM2NmpD1hXFtTqs9h90qjHdC2F?usp=drive_link
        is the new link with what you asked for. It is also editable by yourself if you'd like.
        Sadly not the way I want it.
        It has to look like this :
        https://drive.google.com/drive/folders/1f_jXMG0XMBdyOOBpz8CHM6AFj9vC1R6m
        • FollyF
          Folly @bbilford83
          @bbilford83
          My experience with "Orionsangels Realistic Overlays" is that overlays are always customized by the resolution from the initial user.
          So if @duglor runs with 1920x1080 and you with 1600x900 then the values don't match up anymore.
          Then @duglor made it for 1920x1080, for example.
          So back to my example with "ORO".
          These overlays are made for 1920x1080 and I run on 1600x900 so the widht (x) and height (y) values have to be re-calculated.
          So if we want to re-calculate the values when using, for example 1600x900, we can do it like this for the width (x) :
          new_x=initial_x * 1600/1920
          or for the height (y) :
          new_y=initial_y * 900/1080
          So what you need to know is on which resolution you both run and then you can re-calculate it.
          Not 100% sure but I expect it will work like this.
          B duglorD 2 Replies Last reply Reply Quote 0
            bbilford83 @Folly
            @Folly good point, I should've guessed that. @duglor could you share what resolution you are running at? Mine is 1920x1080 and probably that is not what you're using.
            • duglorD
              duglor @Folly
              @Folly I'll check my resolutions
              duglorD 1 Reply Last reply Reply Quote 1
                bbilford83
                @Folly if you are interested, I finished all my testing for the two sources of "Zemmix" games - your list of all korean-made MSX1 and MSX2 cartridges and the "zuul" list you found online. Just from those, I have a gamelist now with 138 games that work well and don't use the keyboard at all. I did occasionally add another game that was either a sequel or came out before a game already on my list, and those are on there too. Regardless I have added them to my google drive folder shared already (the one starting with retropie as root) with the folder structure correct for them (although this one I have gamelist in the gamelists folder rather than in the roms folder, long story as to why).
                This list is definitely super under-inclusive... and more and more I think it is maybe it is as little as 1/10th of the games that would work on an actual zemmix. I wish there was some shortcut to figuring this out but I think the only way is for me to test all the roms for both msx1 and msx2 cart, which I doubt I'll do (it would take weeks and weeks). But I may at least give msx2 a try.
                FYI I also took notes on games that didn't work for some reason, or have issues. Snake-It and the MSX 1 version of 1941 both only work if you disable the first joystick (so if there is some way to do it from the command line they would definitely benefit). All of the following have some flaw that won't let you get into gameplay (either stays black forever, reboots over and over, or won't let any controls work): Dr. Hello, Eagles 5, Ninja Jajamaru-Kun, Tetris (only MSX1 version, MSX2 version works perfectly).
                If I do test more I will update the gamelist as I do, but I will probably switch to trying out the C64GS next. I'd also welcome any ideas on how to avoid doing it game by game but not even the Zemmix fansites seem to have any lists that would help so I think I am out of luck. Regardless, it's neat to have the system working well.
                Edit: just to see I tested MSX2 "A" games, and there were four more working ones, including the original "Aleste" which is an excellent shmup. I guess that is good and bad news :(. The MSX1 library is huge compared to 2, also...
                • FollyF
                  Folly @bbilford83
                  @bbilford83
                  If we want to share a gamelist for Zemmix then it's probably the best way to separate it from MSX.
                  So you use the MSX2 Zemmix so I think I will call it zemmix2 which can do both msx1 and msx2 zemmix games.
                  For the msx1 versions I call it zemmix.
                  I could also try and add that 1 joystick on port1 is active.
                  Though I have to find how to disable the one on port 2.
                  An other way of determining the roms for zemmix would be to filter with grep on "zemina" seems there are also years in the roms to filter on like "1987".
                  Sadly the ones, not made or distributed by Zemina will not be in the list.
                  And all roms have to be extracted before the filter can do it's job.
                  Anyhow, I think this is also not a perfect way.
                  • FollyF
                    Folly @bbilford83
                    @bbilford83
                    The zemmix/zemmix2 detection enabled now in 260.09.
                    About the joystick problem, I haven't added stuff yet.
                    Can you also try the cpc61 Zemmix MSX2 to see if that type has the same issue ?
                      bbilford83 @Folly
                      @bbilford83
                      So you mean you want me to change the gamelist and image filepaths so they say "zemmix2" instead of "msx2"? I am happy to if you want, I just kept it in msx2 because I don't have any other msx games on my system.
                        bbilford83 @Folly
                        @bbilford83
                        OK, I will test it soon. The cpg-120 is a more powerful system, right? I guess that it still might have an issue the older one won't. I assume I need a different cpc-61 bios too.
                        • FollyF
                          Folly @bbilford83
                          @bbilford83
                          They are both MSX2.
                          Indeed, could be that the cpc61 doesn't have the issue.
                          I know that the cpg120 also has a yamaha ym2413 music chip.
                          Not sure about the cpc61 yet.
                          Yes
                            bbilford83 @Folly
                            @Folly FYI I tested cpc61 and it works, same Zemmix load screen. In general everything is the same, except:
                            1. for some reason it makes the MSX1 version of 1941 work without you having to disable controller one. So that's good I guess. But Snake-It still requires you to do that on both systems. And the games I described not working above still don't work in the same ways.
                            2. I couldn't test the tetris MSX 1 version at the same time as I have the MSX 2 version in my system because they have the same filename. If you change the filenames it messes with mame, so I'm not sure how you could do this with both games in one system.
                            • FollyF
                              Folly @bbilford83
                              Thanks for testing !
                              I am now testing it on Manjaro an Arch linux version using ArchyPie (the clone of RetroPie for Arch linux).
                              Seems I don't have this problem with 1942 on this environment.
                              Also with the latest tests I did on Debian11 with RetroPie also worked good with 1942.
                              So not sure if it's a mame issue or something else.
                              I had the problem earlier on in Debian11, perhaps updates resolved it.
                              Will test Snake-it later how it will react.
                              Don't mind trying to disable a joystick, will have a look if I can.
                              1. I couldn't test the tetris MSX 1 version at the same time as I have the MSX 2 version in my system because they have the same filename. If you change the filenames it messes with mame, so I'm not sure how you could do this with both games in one system.
                              In my script I added the option to "install the patched"/"restore to the origina"l runcommand.sh.
                              If you install the patched runcommand.sh and install the zemmix or whatever system again it will add "extra replace tokens" in the runcommands.
                              You can read the help of the option where you can install/restore it.
                              One replace token will add the softlist option to the runcommand when using the basename runcommand and forces to load the correct tetris.
                              In order to work you have to put the tetrises into the correct folder :
                              /roms/zemmix2/msx1_cart/tetris.zip
                              /roms/zemmix2/msx2_cart/tetris.zip
                              Edit 1 :
                              Found that the variable is not updated when doing both options installing the patched runcommand.sh and then directly install a zemmix system.
                              You have to exit the script, enter it again then install the zemmix.
                              Will have a look later to fix this issue.
                              Edit 2 :
                              Should be fixed now in 260.11.
                              • FollyF
                                Folly
                                @DTEAM
                                Can you look at my PR ?
                                Will try to add zemmix and zemmix2 later.
                                • FollyF
                                  Folly @bbilford83
                                  @bbilford83
                                  Tested snakeit on my Manjaro linux.
                                  Controls working ok on both cpc61 and cpg120.
                                  I have to add that I have to use "space" to enter the game.
                                  For msx2_cart/1942 I also have to use "space".
                                  Though I recon that you don't see using the "space" key as an issue, or do you ?
                                  Tested on Debian11 with the same result.
                                  However both test where without connecting a joystick using the keyboard as joystick.
                                  So now I can't move in msx2_cart/1942.
                                  So the issue is still there.
                                  Ejecting the first joystick worked for both cpc61 and cpg120.
                                  Didn't test it again on Manjaro but I expect the same behaviour.
                                  Found here how to eject the first joystick :
                                  https://arcade.vastheman.com/minimaws/machine/cpc61
                                  Entering - in the joystick setting revealed that we need to add :
                                  -gen1 ""
                                  -gen1 '' (with single quotes will also work)
                                  Implemented it in the script version 260.10.
                                  Edit :
                                  Sorry, I had to remove it again in 260.12 as it doesn't work in lr-mess.
                                  • duglorD
                                    duglor @duglor
                                    @duglor Because of the blocky basic nature of the games, i thought the speed of the paddles in blockbuster games would be helped by a lower resolution. So all of my 4 games are set to 640x480.
                                      bbilford83 @Folly
                                      -gen1 ""
                                      Edit :
                                      Thank you for figuring it out and trying! I wonder if I edit that in manually into a new line of an identical emulator command in the emulators.cfg file if that would let me pick it and have it work? [Edit: it does not, that is probably what you mean that it was not working in lr-mess.]
                                      Also thank you for the tips on how to get it to let two identical named games work, I will probably try to figure that out at least if there are other games like that. There's not much of a reason to have the first Tetris versus the upgraded one but since I am doing it for 1942 anyway I might want to.
                                      FYI, I have been adding and testing all the MSX 2 cartridge games and a huge number of them do work properly. I am up through the G games and so far it is like close to 20 more games. I don't know if I will have the energy to do the MSX-1 list but I will at least update my game list when I am done with dispatch. And I will post if there are other games that require the joystick one to be disabled, so far to my surprise there have not been.
                                      Edit: I found one more that is like Snake-It and still requires you to disable the first joystick to have the controls work: "Return of Jelda". It's an interesting "3D" shooter (like vector graphics but sort of isometric) that I think was an MSX2 exclusive. Also Korean-made, coincidentally I guess.
                                        bbilford83 @duglor
                                        Thank you! I will test this out later today. Funny enough I also use 640 times 480 within retroarch but my overall setting from the command line is still the larger one so I suspect that is what it is tracking to?
                                        duglorD 1 Reply Last reply Reply Quote 0
                                        • duglorD
                                          duglor @bbilford83
                                          @bbilford83 Yeah the named .opt files for the 4 microvision games have resolutions set to 640x480. My default outside those 4 is 1920x1080.
                                            bbilford83 @duglor
                                            Strangely for me when I change the resolution down to 640 x 480 in the runcommand menu the game doesn't boot, just puts me back in emulationstation. @Folly any idea why this would be?
