    • FollyF
      Folly @jamrom2
      @jamrom2
      I am doing many changes and came across some issues I am trying to fix.
      I advise you to wait a while until I think it's stable.
      • jamrom2J
        jamrom2 @Folly
        @folly No problem.
        Just let me know and I'll pull it down.
        • FollyF
          Folly @jamrom2
          @jamrom2
          It looks like it's all stable now.
          I would suggest you try this one (this file will always be the same) :
          https://github.com/FollyMaddy/RetroPie-Share/blob/7017185fb4756559de9ce31f7f22afdf24f09111/00-workdir-00/backup/add-mamedev-systems-0238_test.sh
          Meanwhile I will work towards new updates.
          I have changed, added and improved a lot of things when starting to work on this test script :
          • improve menu text and help text
          • add plain lr-mess loaders that don't use the run_mess.sh script
            • reorganise the options in the commands so the savestate files don't have the command options in the filename (only issue is a space in the beginning of the filename)
          • change the name of the lr-mess loaders that do use the run_mess.sh script and add -autoframeskip to the name
          • prevent downloading the current version run_mess.sh script every time a system is installed
            • it will download the first time when a system is installed, next time it will skip this version.
            • this will help to prevent saving a corrupt run_mess.sh script when there is a bad internet connection
              • a corrupted run_mess.sh script could be the reason why the loader doesn't work
            • if the database and run_mess.sh script are both stored locally then the script can be used offline
          • shorten the names of the all the loaders with extra options so we can find better what we need
          • remove the options in the filename of the generated basename/cmd module-scripts
          • add config directories to all the loaders
            • normally a mame directory was created in the roms/<system> directory now the mame and lr-mess configs are stored in /opt/retropie/configs/<system>/mame (or lr-mess) (here are also the game-specific configs)
          • add both rompaths BIOS/mame and roms/<system> to all the loaders
            • now we don't need to add , for example, "extended basic roms" to the BIOS/mame anymore if the are in the correct path of the roms/<system> directory (for the ti99_4a this will mean that the BIOS ti99_4a.7z is placed and found in BIOS/mame and that the extended bios superxb is placed and found in roms/ti99_4a/ti99_cart, so the superxb doesn't have to be placed in BIOS/mame anymore)
          • add extra predefined install options for ti99_4a
            • loaders with different floppy drive types
            • loaders with editass (editor/assember) needed to load PD/c99/asm software like "Attack of the Creepers" or asm games from "tigameshelf"
          • remove an obsolete function
          • FollyF
            Folly @jamrom2
            @jamrom2
            To make it working we really need to explore how this machine works.
            I learned a lot of the ti99_4a and how it works.
            In basic or extended basic (superxb) we can list what files are on the disk with call dir(1).
            Loading files in basic old DSK1.<FILENAME>.
            Typing run will run the file.
            In the editor/assembler (editass) we can type 5 and type the filename DSK1.<FILENAME>.
            The the game will start.
            Some disk images are only properly read when using the correct floppy type.
            I used both 525dd and 525qd successfully.
            You also have to set the correct DIP switches in the GUI. (40 track / 80 track)
            resized_2022-01-31-112410_800x600_scrot.png resized_2022-01-31-112411_800x600_scrot.png
            This is an example of loading "Attack of the Creepers" (dsk file is 254.1kb using 525qd / 80 track/2ms) :
            resized_2022-01-31-112412_800x600_scrot.png resized_2022-01-31-112430_800x600_scrot.png
            resized_2022-01-31-112450_800x600_scrot.png resized_2022-01-31-112508_800x600_scrot.png
            resized_2022-01-31-112515_800x600_scrot.png resized_2022-01-31-112527_800x600_scrot.png
            jamrom2J 3 Replies Last reply Reply Quote 0
            • jamrom2J
              jamrom2 @Folly
              @folly I'll be working with it tonight, but I can see you've done an amazing job on it.
              This is more than any other emulator does. You're really able to work with it as if you're actually adding in modules and cart to run basic.
              I assume it was done this way originally because the original system had no DOS system, much like a C64 or Tandy, not like MS-DOS based PC's that you loaded DOS onto a HD. Back then.. no HD's. LOL.
              This is good. I'm sure there are a TON of games that will run now, just have to figure out what they need to run. I've pulled down many and just committed to them not working. I'll be messing around with all these options to try and get them to work now.
              • jamrom2J
                jamrom2 @Folly
                @folly I also found with your script, that you can use it per game name as well. What I mean by this, is there are some compilation disks out there that are driven by a menu. Menu loads, select a game.
                Your script actually allows you to use the same file as many times as you want and just rename it to the games that are on it. So if there is defender, Poker, Adventure.. whatever listed on the disk. The one file can be copied and just renamed Defender.bin, Poker.bin or whatever it's listed as. If it's a game in basic, drop the .bin as you know. Then select the correct loader.
                What this means is you don't have to go out into the internet and spend HOURS looking for a specific title if it's part of a compilation disk. Your script will read it and load it as long as you name the file correctly as listed on the file directory of the disk. Not sure I've seen that before.
                • FollyF
                  Folly @jamrom2
                  @jamrom2
                  I read you post several times it's a very nice feature.
                  It looks like you described it thoroughly, though I can't put my finger on it on how/what you did exactly.
                  Can you describe the example more precise, with some steps ?
                  Or did you do this with an autoboot loader ?
                  Then I understand.
                  I probably should add some help pages, for all the features, in the script.
                  • FollyF
                    Folly @jamrom2
                    @jamrom2
                    Forgot to tell.
                    lr-mess seems to have an issue with using shift typing the dot manually.
                    So the example of "Attack of the Creepers", given earlier, is done with mame.
                    Not really sure how this can be fixed with lr-mess.
                    • jamrom2J
                      jamrom2 @Folly
                      @folly Yes, I noticed this. I hadn't said anything because I wasn't sure it was me or Mess. So now you confirmed it. It's not just the ".", it's a few keys in that area. I wonder if there is a region setting for the keyboard? Not sure it made a difference with the Ti99, but it is odd that some of the lower right keys are not working.
                      I remapped the "." to the "-" as I don't see the need for the "-" just yet.
                      • jamrom2J
                        jamrom2 @Folly
                        @folly
                        Ok, I kinda figured my explanation would require further explanation.. lol.
                        I was working with a zipped game file Varloc (1985)(Tandy)[26-3291].dsk When it loaded, it gave me a menu to choose from a list of games on the disk. I took it a step further, broke out of the menu program and with DIR , it produced a list showing all kinds of other games on the disk other than Varloc. berserk.bin, digdug.bin, defender.bin... etc.
                        I renamed the Varloc (1985)(Tandy)[26-3291].zip to berserk.bin.zip and ran it with the new CoCo3 script for Flop1. It worked. It pulled the Berserk game from the disk and ran it. Then I renamed the zip file to digdug.bin.zip, that worked. I've never seen an emulator do this before, where it pulls a game title from a list of games on an .dsk image. Ususally it will only run the main title it was dumped from, which in this case, should have been the menu... or Varloc.
                        At any rate, it might just be me, but I thought it was worth mentioning. So if a .dsk file like this has 10 games stored on it, you could literally rename the .zip file to each game and now have all 10 from 1 .zip file.
                        • jamrom2J
                          jamrom2 @Folly
                          @folly I've been trying all sorts of different disk files tonight. With success and some failures... it's definately a challenge to figure out which disk to choose per game, but many do work once you get it right.
                          I find many seem to work good with lr-run-mess (superxb 525qd). Some examples from TOSEC:
                          13 Extended Basic Games (198x)(-)(PD)
                          D-Station (1988)(John Phillips)[with source code]
                          Draw Poker (1981)(Texas Instruments)[PHD 5037][req. PHM 3026]
                          Night Mission (1985)(Millers Graphics)
                          Old Dark Caves 2 (1986)(Donn Granros)
                          You example for Attack of the Creepers worked for me as well using the same method. So that's good as well.
                          The bigger questions is... how do you know what version of Mess to choose to run the game. And, in the Editor/Assembler, how did you get the file name to run the game? I tried call dir(1), but it just gives me an error. I though "call" was a command for voice anyway.
                          Definitely challenging to get working. The .rpk files all run good. I haven't tried the zipped .bin files, but they worked for me before anyway.
                          Does this support .ctg files?
                          • FollyF
                            Folly @jamrom2
                            @jamrom2 said in Development of module-script generator for lr-mess and mame standalone:
                            No, don't think so, it's ti99sim specific.
                            • FollyF
                              Folly @jamrom2
                              @folly
                              Now I understand,
                              I will try it If I have the time ;-)
                              • FollyF
                                Folly @jamrom2
                                Ok, this solution worked for me too.
                                To be able to use the shift too I had to set the keyboard on emulated instead of natural.
                                Perhaps I have to remove the "keyboard natural mode", what do you think ?
                                • jamrom2J
                                  jamrom2 @Folly
                                  @folly I think that's a good call. I find I have to switch back and forth. But I don't see how to delete on emulated. Works on Natural. I'll just have to re-map the key to something else.
                                  Works better in Emulated anyway.
                                  • FollyF
                                    Folly @jamrom2
                                    @jamrom2
                                    Tested keyboard emulated mode in both mame and lr-mess.
                                    Indeed it works far better.
                                    Improvements with both :
                                    • We are able to use the ti99 function keys, which do not work in natural mode.
                                    • we also reduce the amount of text in our loaders a our and our loader names
                                    Improvements in lr-mess :
                                    • We are able to use capslock and shift and the dot key when reassigned
                                    I will remove the -nat option in all lines.
                                    • FollyF
                                      Folly @jamrom2
                                      @jamrom2
                                      I found that there is still a huge development around the ti99.
                                      A Richard Gilbertson is still working on a combination :
                                      • Rich eXtended Basic
                                      • Rich Editor Assembler
                                      There is a 2021 version in rpk and they are working on a 2022 version.
                                      I think it could replace all superxb and editassloaders.
                                      It looks like this :
                                      You should probably e-mail me so I can give you some more information.
                                      (you can find my e-mail by clicking on my user information)
                                      • jamrom2J
                                        jamrom2 @Folly
                                        @folly I can see where this will definately streamline the loading process, but this is certainly a system you need to have some familarity with or be willing to make input. It's not like a C64, CPC or Atari.
                                        I didn't own one, so it's a learning curve, but fun to use. It's serious old school input when there was not DOS. LOL.
                                        You can hit me on jamrom2 (at) yahoo (dot) com.
                                        I just wish there was a way to improve the performance. I understand why it's poor, many of the discreet circuits on MAME arcade emulator suffer the same. It has to do with how the data is processed in the circuits. Not easy to emulate with software.
                                        Maybe some of this work and that make it available in the Retropie Libretro format will trigger someone to look at it again.
                                        • FollyF
                                          Folly @jamrom2
                                          Indeed, same with me.
                                          I did a commit :
                                          https://github.com/FollyMaddy/RetroPie-Share/blob/de4c502ef629317ff9eb6740739c42f46d21b3fc/00-workdir-00/backup/add-mamedev-systems-0238_test.sh
                                          Removed the -nat option (keyboard natural mode) and added a few rxb2021 loaders too.
                                          To have a better overview I decided to place the rxb2021.rpk file into :
                                          /home/pi/RetroPie/roms/ti99_4a/ti99_cart_rpk
                                          The rxb2021 loader will search in that directory for the cartridge file.
                                          • FollyF
                                            Folly @jamrom2
                                            As soon as I get in to the GUI, I can check my controller assignments and see why I'm missing "UP". All other buttons and directions work fine.
                                            I tried lr-mess and I had issues also with the "UP".
                                            When I enable "CAPS-LOCK" I am able to use the "UP" key.
