    Help with xboxdrv not installed in Ubuntu 20.10 (Retropie 4.7.9)
    xboxdrvubuntu 20.10playstation2pcsx2
    2 Posts 2 Posters 653 Views
      derebo
      Hi,
      I am running Retropie 4.7.9 on Ubuntu 20.10 on an amd64 computer. I have a "Trust GXT-540 Wired Gamepad | YULA" and I can play all sorts of videogames of different systems with different libretro cores.
      This gamepad has a d-input/x-input swith and I am using d-input switch all the time with no issues.
      As d-input, Ubuntu detects it as
      lsusb
      Bus 003 Device 005: ID 145f:01c5 Trust Trust Gamepad
      sudo dmesg
      [159085.291533] usb 3-1: USB disconnect, device number 4
      [159085.292296] xpad 3-1:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
      [159085.754615] usb 3-1: new full-speed USB device number 5 using ohci-pci
      [159085.949300] usb 3-1: New USB device found, idVendor=145f, idProduct=01c5, bcdDevice= 2.00
      [159085.949310] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [159085.949315] usb 3-1: Product: Trust Gamepad
      [159085.949321] usb 3-1: Manufacturer: SHANWAN
      [159085.959441] input: SHANWAN Trust Gamepad as /devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:145F:01C5.0003/input/input15
      [159086.019149] hid-generic 0003:145F:01C5.0003: input,hidraw0: USB HID v1.10 Gamepad [SHANWAN Trust Gamepad] on usb-0000:00:12.0-1/input0
      I: Bus=0003 Vendor=145f Product=01c5 Version=0110
      N: Name="SHANWAN Trust Gamepad"
      P: Phys=usb-0000:00:12.0-1/input0
      S: Sysfs=/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:145F:01C5.0003/input/input14
      U: Uniq=
      H: Handlers=event12 js1
      B: PROP=0
      B: EV=1b
      B: KEY=1fff000000000000 0 0 0 0
      B: ABS=30027
      B: MSC=10
      ls -alh /dev/input/by-id/
      lrwxrwxrwx 1 root root  10 feb 23 19:52 usb-SHANWAN_Trust_Gamepad-event-joystick -> ../event12
      lrwxrwxrwx 1 root root   6 feb 23 19:52 usb-SHANWAN_Trust_Gamepad-joystick -> ../js1
      evtest /dev/input/event12
      A	BTN_C
      B	BTN_EAST
      X	BTN_NORTH
      Y	BTN_SOUTH
      LB	BTN_WEST
      RB	BTN_Z
      TL	BTN_TL
      TR	BTN_TR
      SELECT	BTN_TL2
      HOME	BTN_MODE
      START	BTN_TR2
      UP	ABS_HAT0Y
      DOWN	ABS_HAT0Y
      LEFT	ABS_HAT0X
      RIGHT	ABS_HAT0X
      LPUSH	BTN_SELECT
      LUP	ABS_Y
      LDOWN	ABS_Y
      LLEFT	ABS_X
      LRIGHT	ABS_X
      RPUSH	BTN_START
      RUP	ABS_RZ
      RDOWN	ABS_RZ
      RLEFT	ABS_Z
      RRIGHT	ABS_Z
      However, when trying to play PS2 videogames on non-libretro emulator pcsx2, the gamepad is not responsive. I was thinking making use of xboxdrv might help detect the gamepad, specifically in pcsx2. I have followed the steps
      https://retropie.org.uk/docs/Universal-Controller-Calibration-%26-Mapping-Using-xboxdrv/
      only to note there is no /etc/rc.local in Ubuntu.
      To make rc.local available and rc-local service enabled and active I have followed
      https://linuxmedium.com/how-to-enable-etc-rc-local-with-systemd-on-ubuntu-20-04/
      Now rc.local is available but installing xboxdrv from EmulationStation > RetroPie > RetroPie setup > Manage packages > drivers > xboxdrv > Install
      and then
      Configuration / Options > Enable xboxdrv
      is not adding any code to /etc/rc.local
      and there is no file either in
      /opt/retropie/supplementary/xboxdrv/bin/xboxdrv
      At this stage I don't know what else to try so any help and advice are much appreciated.
      Thank you in advance!
        mitu Global Moderator @derebo
        @derebo RetroPie logs every installation in $HOME/RetroPie-Setup/logs, can you look into the last log file to see if the xboxdrv installation was successful ? You can also re-run the installation to generate a new log file and then post the log file on pastebin.com.
