    Retropie samba doesn't work
    sambashare filesrom transferwindows 10
    5 Posts 3 Posters 998 Views
    • H
      HairDyeGuy
      Pi Model or other hardware: Zero W
      Power Supply used: Original Samsung adaptive charger
      RetroPie Version Used: 4.5
      Built From: Freeplay Tech image
      I installed a new image on my hard drive because I am building a handheld kit, and when I wanted to transfer ROMs and BIOS files onto it I discovered that my windows can't find the pi. I made sure we're on the same network and typed both \RETROPIE and \10.0.x.xx (the ip) to no avail. I also tried going to the network center and tried scanning for the pi there but it didn't work either. I made sure that the SSH function is enabled (PuTTY command terminal works fine).
      Making it work would make my life a lot easier, especially since EXT2FSD stopped working and I can't just plug in the sd card into my computer (if anyone has an idea about this by the way, it would be very helpful).
      Thanks in advance!
      YFZdudeY 1 Reply Last reply Reply Quote 0
        If SSH is enabled, then use WinSCP to transfer files, instead of file shares.
        • YFZdudeY
          YFZdude @HairDyeGuy
          @hairdyeguy
          The registry edit mentioned here is what fixed the problem for me.
          https://retropie.org.uk/forum/post/252150
          • H
            HairDyeGuy @mitu
            @mitu @mitu
            Sorry for the late reply, I didn't get notified for some reason.
            I ended up using WinSCP, but I prefer it much less than the file share.
            I'll try the registry fix and will report ASAP
            • H
              HairDyeGuy
              @mitu @mitu
