    Question on using Flash Drive for ROM Transfers
    piboy dmgfile management
    3 Posts 2 Posters 494 Views
      Agrajag
      I just got my PiBoy DMB and have to say that transferring roms to it via the flash drive was just amazing. It worked so flawlessly. However, now I have a question. What happens AFTER the first time you do this?
      Say I want to remove a ROM, or want to add another? Do I have to wipe everything, or is this now forever a comparison between two devices? It seemed that when I added a ROM (with the original set already there, that it just copied everything over again and not just the new ROM.
        dankcushions Global Moderator @Agrajag
        @agrajag if you want to remove a rom, delete from your SD card. whatever is on the USB stick will be copied over (if a given file already exists in the same location on your SD card, it won't copy).
          Agrajag @dankcushions
          @dankcushions Thank you. Great to know.
