    Making a console (rpi 4)
    helpraspbianretropierpi 4software
    36 Posts 5 Posters 6.6k Views
    • omission229O
      omission229
      Hello again my very awesome friends. So I want to get a raspberry pi 4 (4 gb version) and make a console. I will use Retropie (or maybe Raspbian and install Retropie inside of that). So, I have found a case for the pi and I have a 32 gb sd card. Where will I begin? It doesn't need to be a fully fleshed out handheld. By console I meant just something that you can connect a controller to, plug into your TV and start playing.
      Z lostlessL 2 Replies Last reply Reply Quote 0
      • Z
        Zering @omission229
        @omission229 The Pi and the case are your basics. But for the best experience you will also need the official power supply for the pi and a cooling solution. I recommend a small fan and heat sinks.
        • lostlessL
          lostless @omission229
          @omission229
          https://retropie.org.uk/docs/First-Installation/
          And follow these instructions. It will set you on your way to start.
          • omission229O
            omission229
            Thank you my friends. Both are very helpful.
            • omission229O
              omission229
              Are these good?
              https://www.amazon.ca/gp/cart/view.html?ref_=nav_cart
              https://www.buyapi.ca/cart.php
              • Z
                Zering @omission229
                @omission229 You've just put up links to your carts, we can't see anything.
                • omission229O
                  omission229
                  Hopefully this is better.
                  https://www.amazon.ca/gp/product/B00P0DSHPW/ref=ox_sc_act_title_1?smid=AKXVBT49GGF3B&psc=1
                  https://www.amazon.ca/gp/product/B073JYVKNX/ref=ox_sc_act_title_2?smid=A2U7BYCM1HXLY3&psc=1
                  https://www.amazon.ca/gp/product/B088D14MK1/ref=ox_sc_act_title_3?smid=AMIHZKLK542FQ&psc=1
                  https://www.buyapi.ca/product/raspberry-pi-4-model-b-4gb/
                  https://www.amazon.ca/gp/product/B07VFR96YS/ref=ox_sc_act_title_4?smid=ANP120TAQRWM2&psc=1
                  • Z
                    Zering @omission229
                    @omission229 All looks good to me.
                    Just be aware that the extra 2 GB of Ram you get with the 4 GB board will never be useful to you. You might want to save a few bucks and go for the 2 GB board.
                    • omission229O
                      omission229
                      Hmm, are you sure? For both emulation and desktop?
                      • Z
                        Zering @omission229
                        @omission229 I don't know about desktop apps but 2 GB of RAM is more than sufficient for any emulation you'll attempt on the pi.
                        • omission229O
                          omission229
                          Ok, so I'll get the 2 gig one.
                          • omission229O
                            omission229
                            Also, I have a question. For the Piboy dmg, why do you need the 4gb one if its useless?
                            • omission229O
                              omission229
                              So one thing I'm worried about. How do I connect the pi to the tv?
                              mituM IanDaemonI 3 Replies Last reply Reply Quote 0
                                mitu Global Moderator @omission229
                                @omission229 said in Making a console (rpi 4):
                                Using the miniHDMI cable ?
                                • IanDaemonI
                                  IanDaemon @omission229
                                  This post is deleted!
                                  • IanDaemonI
                                    You'll need to convert the micro-HDMI output (on the Pi4) to full-HDMI input for the TV.
                                    • omission229O
                                      omission229
                                      How do I do that? I am new to this HDMI.
                                      IanDaemonI mituM 2 Replies Last reply Reply Quote 0
                                      • IanDaemonI
                                        You use a cable or an adapter. It just makes the little HDMI port and the big HDMI port work together. I'm sure they have cables and adapters for sale online. You can check your preferred Internet shopping site.
                                        OR
                                        • omission229O
                                          omission229
                                          Oh, I posted a hdmi cable on this thread. Just scroll up and you can see the link. Is this what you mean? Yes thats the one I found so is it good?
                                            Did you ever connected anything to your TV so far ? How did you do it ? HDMI is just a port in which you connect the audio/video cable. Want to read more - check out the Wiki page about it.
                                            The 1st Amazon link posted is for a minimicroHDMI to HDMI cable, that should be enough to connect your Pi4 to the TV.
                                            IanDaemonI 1 Reply Last reply Reply Quote 1
