    Wireless devices for retropie: usb wired, bluetooth or battery-powered?
    gamepadkeyboardretropiewireless
    1 Posts 1 Posters 375 Views
    • N
      niculinux
      Hello vaery again! Following this thread here i've enough of wired devices that make a mess over the rooms, so i'm thinking to switch to wireless ones, so what you woud advice between bluetooth or battery powered ones? As for the latter, rechargeable ones are better? And there are even other alternatives?
      As a bonus, would you advice some of the above mentioned that are compatible and 100% working with retropie? I mean mostly gamepads, joysticks and keyboards, possibly with an integrated touchpad, with a non intensive everyday usage.
      In case i should pick a bluetooth controller, do you advise ti buy an external tongle to pair it with my Pi3 or i migh use the built in one?
      Whatever, thanks in advance!
