    [DOLPHIN] .wad files problem
    retropiex86dolphinwad
    4 Posts 2 Posters 1.8k Views
    • saku00S
      saku00
      PC: with core i5
      OS: Ubuntu 20.04/Retropie X86
      Emulator: Dolphin/Wii
      What should I do to make retropie recognize the .wad files? If I put any .wad (wiiware) file in the retropie wii folder the file is not recognized (not seen).
      If, instead, I open the dolphin gui (terminal /opt/retropie/emulators/dolphin/bin/dolphin-emu) and open any .wad file, all works perfectly.
        That's because the wii platform doesn't have the .wad extension included (see here).
        We'll add it to the list of known extensions.
        saku00S 1 Reply Last reply Reply Quote 0
        • saku00S
          saku00 @mitu
          @mitu thanks, i manually edited the es_systems.cfg file and now it works perfectly
            mitu Global Moderator @saku00
            @saku00 Well, the addition is now part of RetroPie, so you don't have to edit the file again if you update Dolphin.
