    Automatic runing command at start. How to?
    autobootautostartcomandruncommand
    5 Posts 2 Posters 1.1k Views
    • I
      IGA
      Hello
      Could somebody tell me how to make command:
      sudo python3 tweakvec.py --preset PAL60
      run always automatically when raspberry pi turned on?
      ( I've tired to write this command manually each time after retropie loading, so maybe could add this command like autoboot? I'ts just need ti fix colors of my TV)
        mitu Global Moderator @IGA
        Add the command to the autostart script - see https://retropie.org.uk/docs/FAQ/#how-do-i-boot-to-the-desktop-or-kodi -, before the EmulationStation command.
        • I
          IGA @mitu
          @mitu alright, i do /opt/retropie/configs/all/autostart.sh - and wrote there my command: sudo python3 tweakvec.py --preset PAL60.
          But after next reboot nothing happens.
          Even if I write there " sudo python3 /home/pi/tweakvec.py --preset PAL60 " nothing happened too
            Does this command work from the command line, if you launch it manually ? You need to give the full path to the script, because autostart.sh doesn't necessarily run from /home/pi.
            Post the complete autostart.sh file.
            • I
              IGA @mitu
              @mitu оООО!
              Oh thank you! on the hundredth attempt, it still worked itself
              • -magic!?))
