    Help with button mapping / Pi inside A1up
    button mapping
    1 Posts 1 Posters 377 Views
      Drifty
      I'm using a Final Fight Arcade1up, I want the buttons to work the same as the original front end. So basically the 1p and 2p start buttons are coin and start, and then hold either of the starts for a couple seconds to exit back to frontend to select another game. I've not found a way to get this to work in the menus, is this possible or am I wasting my time? I don't have any extra buttons to use as a quit retroarch / hotkey so that's out of the question.
      Thanks.
