    Disable PS3 controller rumble lr-pcsx-rearmed
    29 Posts 13 Posters 17.0k Views
      AlmightyHeretic @Beretta9
      @Beretta9 I'm using wireless 360 controllers and experiencing the same problem. :/
        SOSretro
        I posted a pull request a while back, but it has had little movement (from what I can tell). Added a comment about this thread to show there were a number of users having the same problem.
        https://github.com/libretro/pcsx_rearmed/issues/56#issuecomment-252421601
          AlmightyHeretic @SOSretro
          @SOSretro Doesn't look like they've given it any attention. Maybe I'll have to create an account and comment. More comments = more attention?
            dankcushions Global Moderator @AlmightyHeretic
            @AlmightyHeretic not really.. more coders = more action :)
              SOSretro
              @dankcushions,just want to add my appreciation for the developers who work on these projects in their spare time! I only added the link so it was clear it wasn't 100% user error. :)
                pjft @SOSretro
                @SOSretro
                I just submitted a PR for this. Hopefully it'll be approved in the coming days and then, if you update lr-pcsx-rearmed, you'll be able to disable vibration as a Core Option.
                  edmaul69
                  @Fenthor @Beretta9 @Junglist @AlmightyHeretic @xwons @prosthetichead @SOSretro You can use @pjft 's fix to turn it off or use a usb bluetooth. In my testing th stuttering only does it on the built in bluetooth.
                  • TMNTturtlguyT
                    TMNTturtlguy @edmaul69
                    @edmaul69 in my testing it also happened over wireless USB. @pjft fix wired for wireless USB as well.
                      edmaul69 @TMNTturtlguy
                      @TMNTturtlguy could be the usb bluetooth device you are using. Mine worked great. Mine isnt one of those nano adapters though. Mines about an inch long.
