    Trying to fix vertical display on Pi4
    display issuemodding
    1 Posts 1 Posters 370 Views
      tmoe01
      I'm looking for help to get a full vertical setup on an SF tabletop that I am modding. I have it at 3/4 of the vertical screen, but it is also cut off on the right. Here are some of the settings I have:
      In the /boot/config.txt, I have these settings:
      disable_overscan=1
      hdmi_group=2
      hdmi_mode=32
      Ok so going into Retropie Setup>Config/Tools>Autostart>Manually Edit and I have
      emulationstation --screenrotate 3
      --screensize 960 1280
      emulation station #auto
      In Retroarch>Settings>Video>Scaling
      Integer Scale is off
      Aspect Ratio is custom
      Custom Aspect Ratio X is 0
      Custom Aspect Ratio Y is 32
      C A Ratio width is 960(3×)
      C A Ratio height is 1280
      Crop Overscan (Reload) is on
      In Fullscreen mode both settings are on
      In Windowed mode
      Windowed scale is 3.0x
      Window Opacity is 100
      Show Decorations is on
      Remember P&S is on
      Window width is 960
      Window height is 1280
      I also followed @mitu steps from another post and added video=HDMI-A-1:1280x960M@60,rotate=90 to the end of /boot/cmdline.txt
      I also added video_allow_rotate=yes and video_rotation = "3" to /opt/retropie/configs/all/retroarch.cfg
      I'm not sure how to correct this and I really dont wanna mess with the config because trying to tweak it caused me to white screen it and it was a pain to recover from it. Any help is appreciated
