    No Wlan0 interface detected
    no wifiwifiretropie 4.4.2
    29 Posts 4 Posters 11.7k Views
    • Thorr69T
      Thorr69 @Seannyboy08
      @seannyboy08 I think he's more interested in making sure you grabbed the right image for your hardware. You should have downloaded the rpi2/3 image (assuming this is still the Pi 3b in your post above).
      RPi 3b
      Official PSU
      Official RetroPie image
      Pandora's Box 5 controller
        mitu Global Moderator @Seannyboy08
        @seannyboy08 said in No Wlan0 interface detected:
        Literally the image file you asked me to download from scratch but if you think its the image file got currupted during the writing process i'll try again or is there another image file you recommend ?
        In this case I don't understand why the WiFi is completely disabled or not present. Can you post the contents of the config.txt configuration file from the sdcard, should be accessible if you insert the sdcard into your PC from the boot partition that shows up.
        Seannyboy08S 1 Reply Last reply Reply Quote 0
        • Seannyboy08S
          Seannyboy08 @mitu
          Here is the config file from the sd card, hope this helps -
          # http://rpf.io/configtxt
          #hdmi_safe=1
          #disable_overscan=1
          #overscan_left=16
          #overscan_right=16
          #overscan_top=16
          #overscan_bottom=16
          # overscan.
          #framebuffer_width=1280
          #framebuffer_height=720
          #hdmi_force_hotplug=1
          #hdmi_group=1
          #hdmi_mode=1
          #hdmi_drive=2
          # no display
          #config_hdmi_boost=4
          # uncomment for composite PAL
          #sdtv_mode=2
          #arm_freq=800
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          # Uncomment this to enable infrared communication.
          dtparam=audio=on
          [pi4]
          # Enable DRM VC4 V3D driver on top of the dispmanx display stack
          dtoverlay=vc4-fkms-v3d
          max_framebuffers=2
          [all]
          #dtoverlay=vc4-fkms-v3d
          gpu_mem_256=128
          gpu_mem_512=256
          gpu_mem_1024=256
          overscan_scale=1
          Sean
            @seannyboy08 Looks fine, WiFi is not disabled here.
            Seannyboy08S 2 Replies Last reply Reply Quote 0
            • Seannyboy08S
              Seannyboy08 @mitu
              Any ideas as to why i can't connect to the wifi ?
              Sean
              • Seannyboy08S
                Seannyboy08 @mitu
                Is it out of range possible ?
                Sean
                  @seannyboy08 I don't think being out of range is the issue here - your WiFI interface is not working on the Pi, before even trying out to connect to an access point (which may or may be not out of range).
                  Can you run the following commands and post the output:
                  iw reg get
                  rfkill list all
                  systemctl status wpa_supplicant
                  • Seannyboy08S
                    Seannyboy08 @mitu
                    answer to the f4 command prompts -
                    iw get reg
                    global
                    country 00: DFS-UNSET
                    (2402 - 2472 @ 40), (N/A , 20), (N/A)
                    (2457 - 2482 @ 20), (N/A , 20), (N/A), AUTO-BW, PASSIVE-SCAN
                    (2474 - 2494 @ 20), (N/A , 20), (N/A), NO-OFDM, PASSIVE-SCAN
                    (5170 - 5250 @ 80), (N/A , 20), (N/A), AUTO-BW, PASSIVE-SCAN
                    (5250 - 5330 @ 80), (N/A , 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
                    (5490 - 5730 @ 160), (N/A , 20), (0 ms), DFS, PASSIVE-SCAN
                    (5735 - 5835 @ 80), (N/A , 20), (N/A), PASSIVE-SCAN
                    (57240 - 63720 @ 2160), (N/A , 0), (N/A)
                    rfkill list all
                    0: hci0 : Bluetooth
                    soft blocked: no
                    hard blocked : no
                    systemct1 status wpa_supplicant
                    wpa_supplicant.service - WPA supplicant
                    Loaded : loaded (/lib/systemd/system/wpa_supplicant.service: enabled; vendor preset: enabled)
                    Active: active ( running) since Thu 2020-08-20 14:17:05 BST: 3Mmin 23s ago
                    Main PID : 427 (wpa_supplicant)
                    Tasks: 1 (limit: 1635)
                    CGroup: /system.slice/wpa_supplicant.service
                    I___ 427 / sbin/wpa_supplicant -u -s -0 / run/wpa_supplicant
                    Aug 20 14:17:05 retropie system[1]: StartingWPA supplicant...
                    Aug 20 14:17:05 retropie wpa_supplicant[427]: Successfully initialized wpa_supplicant
                    Aug 20 14:17:05 retropie system[1] : Started WPA supplicant.
                    Sean
                      iw get reg
                      global
                      You haven't set the WiFi country, as indicated in one of the first replies to your post. Please do so before configuring WiFi - https://www.raspberrypi.org/documentation/configuration/wireless/wireless-cli.md.
