    Port 2 Controls Not Working After Upgrade to Buster
    controls
    2 Posts 2 Posters 181 Views
      pianoman72
      I'm so sorry I have been searching and reading and learning but I can't figure this out.
      I upgraded to Buster today with a fresh .img and copied over .cfg files, etc from the old install.
      The primary reason I didn't want to upgrade is because I have spent so much time getting the controls to work correctly for each game.
      (this is an arcade cabinet with a Xinmotek Controller)
      So port 2, (or should I say player2?) doesn't work in games anymore. (Already we've arrived at the first point of confusion for me.)
      PROBLEM 1 - If I'm in the emulationstation menu, the player 2 controls DO work (all players can control the menu), but select and start are swapped. I thought if I swapped the values for those inputs in /opt/retropie/configs/all/retroarch.cfg it would resolve this, but has no effect.
      input_player2_start_btn = "22"
      input_player2_select_btn = "21"
      I can swap those numbers and nothing happens. What am I not understanding there?
      PROBLEM 2
      In games, the 2nd player controls don't work at all. I think this has something to do with "Port 2" if I go to settings-->input---Port 2 Binds. There is a new device index (index #2) that wasn't there before the upgrade to Buster.
      So in order to get any input on that screen I have to switch to index #2 and it will assign new numbers to all of those old values. So for example what was button '22' becomes '6' but at index #2.
      So great, I change those but how does this translate to emulators? Am I supposed to do "Save Autoconfig," which is within that menu? Or save config on exit? I tried both. I have custom remaps for literally every game so I would really appreciate not having to redo all that work.
      Thanks.
        @pianoman72 said in Port 2 Controls Not Working After Upgrade to Buster:
        Some configuration files might not be correct with the new versions of RetroArch. Which version of RetroArch did you have before the update ?
        Not sure if configuring in retroarch.cfg overrides the autoconfig profile values. Where did you get the 21, 22 values ? The numbers look way high for a button number.
        Did you install any aditional drivers in RetroPie ? If you have a 2 player controller, you should have index 0 and index 1.
        How many gamepads does the system detect ? Did you add the USB quirks for this controller - see https://retropie.org.uk/docs/Xin-Mo-Controller/ ?
