    8bitdo Pro 2 controller and Amiberry - No vibration
    amiberry8bitdoretropie 4.7.13
    4 Posts 3 Posters 1.4k Views
      Jimi007
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) Pi4
      Power Supply used: (If using a Pi) Original Pi supply
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.7.13
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used) Original Image
      USB Devices connected: USB keyboard and mouse
      Controller used: 8bitdo Pro 2 Controller
      Error messages received: N/A
      Verbose log (if relevant):
      Emulator: (Name of emulator - if applicable) Amiberry 3.3
      Hi
      Just wanted to find out if there is a way to enable the vibration feedback through Amiberry 3.3 on my 8bitdo Pro 2 controller
      The vibration works fine in Windows as I have tested.
      I cannot seem to get it to work in retropie or Amiberry.
      I have tried the retroarch quick menu and could not see enable vibration (as I 've seen suggested)
      I have also tried changing the controller to retropie with analog in the retroarch menu.
      Controller works fine just the vibration feedback.
      Any help appreciated
      regards
      Jimi
      • L
        loopsheloop @Jimi007
        @jimi007
        Hey, not an expert, but I tried to set up rumble on an SN30 Pro recently. You might need to be in x-input mode, if you're not already, and on the Pro there's a button combo to turn on rumble on the controller - maybe check the manual to see if the Pro 2 has something similar.
        On the Pro, x-input would lead to the triggers not being recognized, so I ended up leaving it in d-input anyway without rumble. Just out of curiosity, what Amiga games are you trying to play with vibration?
          Jimi007 @loopsheloop
          @loopsheloop
          The Pro 2 has an x-input mode which is Windows , d-input , Switch mode and mac mode.
          The x-input does have vibration when I test it in Windows.
          In retropie I was having an issue with connecting to the controller through bluetooth so I reimaged retropie. I then set the controller up through switch mode as it was mentioned this connects better in retropie.
          I will try and connect it in x-input mode and see how that goes. Hopefully I don't need to reimage retropie again :)
          So far I have tried Paradroid 90 , Speedball 2 and Pinball Dreams. No vibration on any
          regards
          Jimi
          • Thorr69T
            Thorr69 @Jimi007
            @jimi007 Ok, so, I was an OG Amiga user. I had a 500, 2000, and a 3000. Amiga was made long before any console has force feedback of any kind. So, why would there be any vibration response in any Amiga game ever?
            I guess I am trying to figure out why you are expecting vibration from a system that never had it. It just seems on par with expecting stereo surround sound from an Atari 2600.
            RPi 3b
            Official PSU
            Official RetroPie image
            Pandora's Box 5 controller
