    Why does EmulationStation keep screwing up my box shots?
    emustationmenupics
    2 Posts 2 Posters 499 Views
      JimmyFromTheBay
      Running ES 2.9.6RP, not a clue if that's the most recent one.
      Daily, across all systems and with no replicatable trigger, ES keeps taking menu pics like this:
      and doing this to them:
      All I did between those two shots was move the highlighted game down from Battle Zone to Defender and back up again.
      Sometimes moving up and down the list fixes it, sometimes it doesn't. Sometimes the same pic will be fine in the system list but bloated up in "Recently Played", or vice versa. What's going on?
        It's a resize issue, I think it's fixed in the development branch of EmulationStation. You can install the dev branch from the experimental section of the packages, it's called emulationstation-dev.
        • J JimmyFromTheBay referenced this topic on
