[SOLVED] No HDMI sound and volume keeps resetting to 0
Hey guys, I know there are a lot of forum posts about this same issue, but I've looked at all of them and nothing has helped. I am building a handheld gaming console with a Raspberry Pi 4 8GB and a 5 inch display. Sound works fine through the Raspberry Pi 3.5mm audio jack, but I wanted to use my screen because it has speakers and an audio jack. However, neither works. The RetroPie volume also keeps resetting to 0 when I change the audio settings to HDMI
My audio settings on the RetroPie main menu are as follows:
- Audio Card: Default / HDMI (I tried both)
- Audio Device: HDMI
- OMX Player Audio Device: Alsa
When I go into alsamixer I am presented with 3 sound cards:
- bcm2835 Headphones
- vc4-hdmi-0
- vc4-hdmi-1
I have tried all three, and none of them work. When I select either of the HDMI sound cards the screen just says "This sound device does not have any controls".
When I go into Raspi-config audio settings and check the different audio output options, only the option for Headphones show up. There is no HDMI options
Here are my HDMI / Audi settings in config.txt:
hdmi_force_hotplug=1 hdmi_group=2 hdmi_mode=87 hdmi_cvt=800 480 60 hdmi_drive=2 dtparam=audio=onI am also not able to plug in any other consoles to the display to test the audio because its glued into my case.
If you have any suggestions, please let me know!
Had a similar issue with trying to get my sound to output to the 3.5mm jack.
https://retropie.org.uk/docs/Sound-Issues/#using-the-built-in-hdmi-audio
Maybe this needs to be uncommented: hdmi_force_edid_audio=1
@bdpyle said in No HDMI sound and volume keeps resetting to 0:
bcm2835 Headphones
vc4-hdmi-0
vc4-hdmi-1You seem to have configured the
vc4-kms-v3doverlay inconfig.txt, instead of the defaultfkmsoverlay. Any reason you've done that ? -
@mitu I'm honestly not sure what that is. I didn't add that to my config.txt. I will say that I have a 64-bit version of Retropie that can run Wii and Gameube games natively, so the OS may have been adited to add that in.
RetroPie support for 64bit is still not part of any official release. Any 3rd party images are not supported here, as stated in https://retropie.org.uk/forum/topic/3/read-this-first.
@mitu Here are the lines in my config.txt file:
# Enable DRM VC4 V3D drive dtoverlay=vc4-kms-v3d max_framebuffers=2 arm_64bit=1 -
@hellothere Just tried uncommenting that, but still no luck.
I am getting the following errors in alsamixer:
VolumeControl::init() - failed to find mixer elements alsactl: get_control:256: Cannot read control '3,0,0,Playback Channel Map,0': Invalid argument -
@mitu So are you thinking that the reason it isn't working is because I am using a 64-bit version of RetroPie?
No, the audio errors are from enabling the
kmsGPU driver, which also adds the new HDMI audio driver.
Other than that, who knows what other configurations have been added to the image by its author - one of the reasons we don't support 3rd party images. -
@mitu Thanks for the help. Just flashed a stock image of retropie onto a new SD card and audio works perfectly through the screen. Going to try removing
dtoverlay=vc4-kms-v3dand see if that works
I successfully replaced the line
dtoverlay=vc4-kms-v3din my config.txt file with
dtoverlay=vc4-fkms-v3dand now everything works perfectly! Thanks for the help @mitu
