    RetroPie Power Button Not Cutting All Power
    power problempowerswitchpowerbuttonpower help
    3 Posts 2 Posters 612 Views
      bdpyle
      Hey guys, this may not be the best forum to post about this, but I'm having a few issues with my current power button setup for my Raspberry Pi handheld.
      Here's my current setup: I have a Raspberry Pi which is being powered by Helder's Retro PSU via a 3.7v 4500 mAh battery. The Pi is running standard 32bit RetroPie. I also have a heatsink with an integrated fan wired to the Pi for better cooling
      Here's the problem: I followed this tutorial
      to set up a power switch for my Pi by wiring a button to pins 5 and 6 on the GPIO pins and running a Python script. The problem is, when I press the power button, the Pi will turn off, but the red light stays on and the fan keeps running. This makes it so the RetroPSU battery indicator LED for when the battery is fully charged will never come on because it's constantly supplying power to the Pi even though it is turned off.
      So here's my question: Is there any way I can modify the script or download a new script that will fully turn the Pi off so it will both fully charge and the fan will turn off as well?
        As long as there's a PSU providing power, the red LED will stay on and the board will still have power - otherwise it wouldn't be able to power back on. You'll need a solution that will cut the power externally - like the Powerblock.
          bdpyle @mitu
          @mitu Oh, gotcha. I'll try that out.
