    Ubuntu PC having issues running ROMs
    ubuntupc retropie
    10 Posts 4 Posters 1.1k Views
      McJones9631
      Hey there, so I moved from a Raspberry Pi over to a full gaming PC, with a quad core AMD processor and 8 GB of RAM. Here's a list of issues I'm having:
      • Controller always gives "✔️ USB Gamepad (121/17) not configured" when in games and games can only be exited from the keyboard
      • "Press a button to configure" barely works
      • Killer Instinct still refuses to open, the only .78 ROM next to its sequel that refuse to open
        I have a video of the happenings from direct controller setup to Killer Instinct crashing here. What can I do to fix all this?
        dankcushions Global Moderator @McJones9631
        @mcjones9631 you can start with providing all the information asked here:
        verbose log especially cruvial for your kinst issue, which i expect will reveal that you have the wrong .zip or .chd for 0.78.
          McJones9631 @dankcushions
          @dankcushions
          Pi Model or other hardware: x68 (x86_64) over Xubuntu 21.04
          RetroPie Version Used: 4.7.18
          Built From: Ubuntu git
          USB Devices connected: WiFi dongle
          Controller used: Retro Power SNES USB controller (worked fine with Pi 3 B+)
          Error messages received: ✔️ USB Gamepad (121/17) not configured over lr-mame2003
          File: /home/retropie/RetroPie/roms/arcade/
          Emulator: lr-mame2003
          Log: https://pastebin.com/DfXWiD72
            G30FF @McJones9631
            @mcjones9631 The log says that kinst.chd is the wrong version. You should double check that you have the right version of kinst.zip and kinst.chd for lr-mame2003.
            As for your gamepad, it's possible that your emulationstation es_temporaryinput.cfg file was corrupted at some point. Emulationstation uses that file to configure inputs for Retroarch and other emulators after you configure a gamepad in ES. Try deleting /opt/retropie/configs/all/emulationstation/es_temporaryinput.cfg, rebooting, and then remapping the gamepad in ES.
            M 1 Reply Last reply Reply Quote 2
              McJones9631 @G30FF
              @g30ff Alright, I did that, and still the issue persists. I completely redid the config for the controller, updated everything, and its till popping up. However, I did find and get Killer Instinct's CHDs up and running so thank you for that.
                G30FF @McJones9631
                @mcjones9631 You might also want to try uninstalling and reinstalling the xpad driver from RetroPie-Setup. Sometimes that can correct issues with gamepads, particularly X-input type pads.
                  McJones9631 @G30FF
                  @g30ff I reinstalled that along with every other controller driver, seems the issue is still there sadly.
                  G 2 Replies Last reply Reply Quote 0
                    G30FF @McJones9631
                    @mcjones9631 Run RetroPie-Setup, Manage Packages, Manage Driver Packages, then select xpad. Select Uninstall, then Install.
                      G30FF @McJones9631
                      @mcjones9631 At this point the only other thing I can suggest is to try doing a full update, including underlying OS packages.
                        @mcjones9631 said in Ubuntu PC having issues running ROMs:
                        This usually happens when your controller doesn't have a configuration file/profile in RetroArch. If you configured your controller in EmulationStation, a RetroArch configuration file for the controller should be created automatically, unless you turned of the auto-configuration of controllers in ES.
                        Is you controller working in EmulationStation, after you have completed the input configuration ? Did you disable the auto-configuration in EmulationStation, by any chance ?
