    Do 3rd party joy cons work with Retropie ?
    controller helpcontrollers
    3 Posts 2 Posters 562 Views
      Soxbrother
      Hello,
      Does anyone use 3rd party joy cons with their Retropie setup ?
      Official Joy Cons work, but they are expensive and you also need to buy a separate charger.
      For my handheld project I would like to use a 3rd party Joy con
      (they can be charged without a separate charging dock)
      or a Joy Con-like controller. (like the Ipega PG-9083)
      So has anyone used these 3rd party Joy Con controllers with Retropie and do they work ?
      Thanks in advance.
      • IanDaemonI
        IanDaemon
        They're just bluetooth controllers, right?
        • Cocktail Cabinet Games
        • Check out the MAME RoW
          Soxbrother @IanDaemon
          @iandaemon said in Do 3rd party joy cons work with Retropie ?:
          Yes.
          If the wireless signal is exactly the same as the official Joy Cons,
          then it should work, I suppose.
          But no way to know for sure, unless someone has tried it before.
