    Setting up a Ipac2
    219 Posts 18 Posters 115.6k Views
    • RiverstormR
      Riverstorm @caver01
      @caver01 said in Setting up a Ipac2:
      I do. It had to do with the single retroarch.cfg file in the configs/arcade folder.
      Thanks Caver, that was it, good memory! :)
      that is different than the one for lr-mame2000 because they both use the mame-libretro config folder.
      Is lr-mame2000 lumped mame4all? When I go to the launch menu with ROMs placed in the mame4all folder I can choose between mame4all or lr-mame2000 but when using Arcade it lumps all lr-mame configs (i.e. - 2000, 2003, 2010, 2014 & 2016) to one folder being mame-libretro?
      his was one reason why I am so passionate about keeping the SELECT key mapped. It has to work for both mame and FBA using the same retroarch.cfg file.
      Yeah lr-fbalpha seems to be the only MAME Libretro core that doesn't accept raw input and relies solely on Select for credits.
      • caver01C
        caver01 @Riverstorm
        @riverstorm said in Setting up a Ipac2:
        I believe lr-mame2000 is the better name for the libretro version of mame4all. It used to be lr-mame4all.
        I think one reason why it is setup together is because lr-mame2000 and mame4all-pi are both built on the same mame code base and require the same romset.
        Arcade combines all arcade emulators (except Daphne which is not really interchangeable with the others). The stand-alones like AdvanceMAME will use their own configs as always, but the libretro cores will share the same retroarch.cfg. Actually, they already shared the one in the all configs directory, but the emulator-specific config ends up coming from the arcade config folder and all libretro cores must share.
        The benefit, even with this limitation, is that all arcade games (except laserdisc) are united under a single menu in ES. Before I started using it, I would show a friend the system, and they would be scrolling through the gamelist looking for their favorite, and I was like, "oh, that one is listed under the FBA emulator," or, "oh, that game is vector, so it is under AdvanceMAME," and they would ask, "what is a MAME?" That's when I knew that having multiple arcade choices in ES--especially multiple MAMEs to choose from--was really confusing the casual user. People would appreciate what I built more if they did not have to hunt for their games. The users don't understand why I would choose one emulator over another for a particular game. They also don't care, so the Arcade folder just cuts through all of that confusion.
        Sure, I need a spreadsheet to keep track of what ROMs I have in there (what sets each one comes from) but it seems like the best option for me.
        I might like to try to unify Arcade with Daphne at some point. I am not sure why that hasn't happened yet.
        • RiverstormR
          Riverstorm @caver01
          Yeah they are the same ROM set 0.37b5. Sorry I might have not worded the question clearly. All lr-mame emulators (2000, 2003, 2010, 2014, 2016), advmame, mame4all, etc. share one retroarch.cfg the should be placed in the arcade folder?
          Also just a quick question for advmame I see a folder under Arcade /home/pi/RetroPie/roms/arcade/advmame that only has file links that point to themselves such as the artwork link is /home/pi/RetroPie/roms/mame-advmame/artwork. Do I configure the options, samples, etc. under it's "home" folder in /opt/retropie/configs/mame-advmame as though it's standalone or create folders here in the directory?
          Also for mame2003. This has actual folders under /home/pi/RetroPie/roms/arcade/mame2003 would I add the config files to these folders or to the native mame-libretro folder?
          Lastly the same for mame4all I take it must be configured in it's home folder /opt/retropie/configs/mame-mame4all.
          I agree that sounds pretty handy. I was just trying to cut out the spreadsheet and maybe use the folder listing of files for what ROM belongs to what emulator and then maybe write a small batch files that copies all directories to the Arcade folder from a USB drive.
          Basically using my directory of ROM files as my spreadsheet for reference. Like my FBA directory is pretty small so I could have one window open with the folder listing on one screen then on the other screen configure each ROM in RetroPie. I think it sorts alphabetically by name from gamelist.xml name so it would require skipping around the list of games.
          Man o'live you can just go on and on in RetroPie. Hopefully I get some point where I spend more time playing than tweaking. :)
          Yeah it sure would be a good fit for adding it under Arcade.
          • RiverstormR
            Riverstorm
            I know the ROMs belong in one folder but I was referring to config files, like samples or in AdvMAME the advmame.rc modifications, mame2003 BIOS files, etc.
            • caver01C
              caver01 @Riverstorm
              @riverstorm The advancemame config files stay where they are. It is not libretro, so the .rc file is still referenced in its existing location. That is convenient at least. The support folder locations for advancemame such as artwork and others are all dependent on the settings in the .rc, so you can leave them where they are, or point them to wherever you think is more convenient. For example, I have my samples in the BIOS area where I setup a folder structure for advmame. This is also where I dropped some files for MESS. Anyway, AdvanceMAME plays nice with the Arcade folder in that it keeps everything else AS-IS. This may be true of any standalone, non-libretro emulator.
              For the libretro cores, if they generate support files next to the roms, these files/folders will appear in the arcade folder when you launch from there. So, stuff like GUI key mapping saved settings per rom, .nv files, and so on will get recreated. I would suggest letting that happen once, then move/copy your existing to retain highscores etc.. I think lr-mame2003 references the BIOS folder for some stuff (samples maybe? Artwork?) Anyway, that stuff does not change. FBA can use the BIOS folder too, which is nice. So your NeoGeo BIOS can sit there and won't need to be in the games list in Arcade. That is true even if you don't use Arcade.
              Anyway, making the transition to Arcade is not that hard, and if you copy roms over instead of moving them, you can refine your setup without losing your existing emulator areas. You will have to pick a default, then go through runcommand for each game that deviates and set the right emulator, but it is worth it. Later, you can try other versions of emulators easily, provided the rom does not change, without having to move ROMs around to different folders. As long as an arcade emulator is installed, it will be available in runcommand under arcade. This is cheating a little, as your ROMs should obviously align with MAME set required, but many classics don't change from set to set.
              No truer statement exists on this forum!
              • RiverstormR
                Riverstorm
                @caver01 Thanks Caver for all the information. I knew you set a default then work you way through the rest by hand. Most are in mame2003 followed by AdvMAME, then FBA. I think I can get a good start on this now. Well soon-ish! ;)
                I think I know this answer but just to verify. I have some duplicate ROMs that are just for testing lr-mame2000. I will need to leave them in the mame4all folder as you can't have the same ROM name from different sets in arcade correct?
                It is good discussion. It is debate that will bring us to recommendations for people, possibly even enhanced documentation in the RetroPie Wiki.
                I am off for the holiday weekend here soon but I do agree with this statement. I know I get a better understanding of how things work from these discussions, unique points of view to see challenges from different perspectives and as you said it might lead to improved recommendations. Also I guess like Andrew said "A quest for knowledge..." which rings a little true for me or at least sounds very sovereign! ;)
                • caver01C
                  caver01 @Riverstorm
                  You can't have two files with the the same filename in any single location--arcade folder or elsewhere. The fact that MAME and FBA use romsets with filenames that don't change (but their contents might) is probably the biggest source of arcade emulation confusion there is. It can be very frustrating, especially for newcomers. It is also why I keep the spreadsheet. You can't tell by looking at a file which set it came from. You can test it against a known set to see if it is compatible, (like with CLRMAMEPRO), but keeping notes about a jumble of ROMs in the arcade folder is worth the effort.
                  • RiverstormR
                    Riverstorm @caver01
                    Ok, I just wanted to make sure I had it straight and there wasn't some clever way to display/run two identically named sets in a list but with potentially different ROM files (i.e. - different MAME versions).
                    When I started using RetroPie it was more learning how to use it and not so much ROM management. The Raspberry Pi and RetroPie merged has been revolutionary for me in making retro gaming incredibly portable in any room or visiting family and friends. Shoot you can take it on a trip even if you're willing to use controllers. It renewed an old spark. I did follow PiPlay for a while but it seemed like RetroPie was evolving quicker.
                    I've used ClrMamePro for about 15 years or so and feel very strong in my ROM management. I have it down to a science mostly but I don't use Software Lists much. They can get a bit advanced if you don't use profiles. It's just repetition of use, reading and using it for years. Learning each option as you go. I remember the days of trying to manage ROM sets without tools or incomplete sets of just the games I wanted to run. I can't imagine not use some type of ROM management now.
                    I run them through ClrMamePro as non-merged, TorrentZip the set and finally zip the whole version. So I have in a folder:
                    • MAME 0.36 Non-Merged (Torrent Zipped).zip (another project)
                    • MAME 0.37b5 Non-Merged (Torrent Zipped).zip
                    • MAME 0.78 ROMs Non-Merged (Torrent Zipped).zip
                    • MAME 0.94 Non-Merged (Torrent Zipped).zip
                    • MAME 0.106 Non-Merged (Torrent Zipped).zip
                    • etc.
                    Then I just pull out the ROM set from the archive I need quick and easy. I use WinMerge if I need to compare to identically named sets for differences or compare folders of sets.
                    I think I can make a folder structure and searching it for knowing which set belongs to which version work pretty easy. The key is knowing that you can only have one version in the folder structure that will be merged into the arcade folder. If I find it in mame2003 on my USB drive then I know it's from 0.78. I suppose I could also pipe the directory to a file but I don't think I would need to go that far.
                    The initial setup seems like it will be slow as you start each game and reference a "list" for the emulator config.
                    I always keep the current set of MAME (split) which I think is 0.191, CHD's and rollback to be able to create any new sets as they are added to RetroPie.
                    Storage is at a high now I think somewhere between roughly 20 to 25 terabytes but about half of that is backup. So really around 12 terabytes of actual data. Always adding drives it seems.
                    • RiverstormR
                      Riverstorm @caver01
                      I wouldn't call it cheating at all! ;) I have 250+ games in mame4all and mame2003 folders. If I compare them as binary they are almost 100% identical directories. On top of that if you TorrentZip your sets they'll have the exact same hash and are 100% identical except for the half dozen or so not supported in mame4all.
                        kombat @caver01
                        I had to go through a bunch of the defaults and set them ="nul" in order to prevent them from overlapping the standard IPAC/MAME mapping above.
                        Where would I go about's setting defaults to nul? Is that in the menu (tab key) once inside a rom?
                        • rbakerR
                          rbaker @kombat
                          @kombat You would be better starting your own thread with a specific question but the answer is no. Are you referring to TAB in MAME? that is how you can make changes but with regard to setting up the keyboard encode you need to read through https://retropie.org.uk/docs/RetroArch-Configuration/#hardcoded-configurations
                          • RiverstormR
                            Riverstorm
                            @kombat - If you're using mame2003 there's a version named mame2003-plus in the Experimental section of the RetroPie setup menu. It has options under Quick Menu/Options once in a game to completely ignore TAB inputs. It might save you from needing to 'nul' every input. It's basically the same core with around 130 additional games and some other improvements. It's Experimental but solid. You can report any issues on the Github page.
                            Input interface: retropad| mame_keyboard | simultaneous
                              kombat @rbaker
                              @rbaker said in Setting up a Ipac2:
                              @kombat Are you referring to TAB in MAME? that is how you can make changes but with regard to setting up the keyboard encode you need to read through https://retropie.org.uk/docs/RetroArch-Configuration/#hardcoded-configurations
                              I'm good with my keyboard encode, my question was in regards to @caver01 setting defaults to null as I am having some similar (i think) issues where the emulator defaults are conflicting with my standard IPAC/MAME mapping (example my player 2 button 6 is triggering a fast-forward?). I am wondering where I can access those settings
                              rbakerR caver01C 2 Replies Last reply Reply Quote 0
                              • rbakerR
                                rbaker @kombat
                                @kombat said in Setting up a Ipac2:
                                By editing the file as shown in the link I posted. You need to access it via SSH.
                                • caver01C
                                  caver01 @kombat
                                  @kombat Yes, the link above that rbaker provided will lead you to a description of /opt/retropie/configs/all/retroarch.cfg which is the global config for retroarch. Inside that file, i set funtions to "nul" that I am not using. I seem to recall needing to do this for overlapping keys on mine as well. Fast foward was one of them as I recall.
                                  As for setting ALL player inputs to "nul" globally--this is NOT what I have done in the past. I only ever did that for a couple of games using rom-specific configs. For example I placed a file into my ROMs folder next to the game rom for vidicators using the format: romname.zip.cfg such that the romname matches. In this file I set all player inputs to "nul" so that I could use the MAME GUI menu <TAB> to define the unusual <CODE_NOT> mapping for a tankstick setup. This is highly unusual, as only a few games require that. I don't rely on this globally because some retroarch emulators don't have a <TAB> feature. FBA for instance won't get very far if you NUL all of your player inputs!
                                    DetroitKp @AndersHP
                                    @AndersHP Hello. I’m new to manually editing Config ALL and have been using TextEdit on Mac. What do you mean that it left the inputs dead? What’s the difference with TextWrangler? Thanks!
                                    AndersHPA 1 Reply Last reply Reply Quote 0
                                    • AndersHPA
                                      AndersHP @DetroitKp
                                      @DetroitKp
                                      Hi, I'm no coder, but there's a difference between curly quotes and non-curly ones.
                                      TextEdit uses the curly quotes, which in coding I guess is wrong.
                                      See here.
                                      My recommendation is to use TextWrangler - it's free and a much better tool than TextEdit.
                                      My Gameboy
                                      • L
                                        Lugzyboy82
                                        I am replying to this topic in the hope that somebody sees this and can help me. Fantastic bit of info on here which has helped me enormously. The only thing I have an issue with is setting up my hot keys in the all retroarch.cfg file. I cant seem to find anywhere that enables me to edit the hotkeys. This is really important as I have a 2 player setup, each with a joystick, 6 in game buttons each (a,b,x,y,l,r) and a start button each. I cant seem to find a section in the config file that allows to set the exit game/exit emulator or pause hotkeys.
                                        Can anybody help?
                                        • L
                                          Lugzyboy82
                                          @caver01 could you please read my comment above to see if you have any help or advice. Thank you.
