    Setting up a Ipac2
    219 Posts 18 Posters 117.1k Views
    • caver01C
      caver01 @Riverstorm
      @riverstorm said in Setting up a Ipac2:
      @caver01 said in Setting up a Ipac2:
      My biggest problem with writing these myself (I could do the more general keyboard controller docs) is that I own a very old IPAC. Mine is a PS/2+USB model that ONLY works as a keyboard.
      I believe they make firmware that allow the newer I-PAC's to be keyboard only. Firmware with game controller support starts with a 3 and without a 4. Basically like 1.34 vs 1.44 or 1.36 vs 1.46.
      Yeah I know, but I can’t use it or experience it. I would be writing about something I have never had to do.
      • RiverstormR
        Riverstorm @caver01
        Ok, I was just pointing that out as I have both both pre and post 2015 (PS/2 and USB). I would assume there's plenty of old boards still in use the only difference between old and new would be one sentence at the beginning mentioning the "keyboard only" firmware update for newer boards as most know how to flash firmware (it's explained on Ultimarc's page in great detail) and the rest would apply the same as your older model was the thought.
          battlecat
          I have had an iPac for at least 6+ years. I think it is the standard keyboard one. I bet that there are still a lot of them out there.
          • RiverstormR
            Riverstorm @battlecat
            @battlecat said in Setting up a Ipac2:
            If it's that old it sounds about right. I have an old and new one. I have no idea how long ago I bought the older one but it's been years and needs the older firmware (pre-2015) or you can brick it. I think the major difference between the two is going to be whether you download firmware "A" or firmware "B" but once they are flashed with the proper firmware the setup should be pretty much the same in regards to setup and configuration.
            • caver01C
              caver01
              Well, I decided to take a crack at it, so here is a first draft of a WIKI document for configuring Keyboard Controllers with special attention to the IPAC as an example. Please, let me know what you think. I sorta ran out of steam at the end and perhaps stopped too abruptly. Feel free to make suggestions to improve or complete this wiki. It is meant more to provide guidance than a step-by-step.
              B AndersHPA 2 Replies Last reply Reply Quote 2
                edmaul69 @Riverstorm
                @riverstorm just thought i would mention that the pre 2015 models that dont have the huge ic chips (really old model have large ic chip) that they can run with a usb cable too even if they came with a ps2 cable. I chopped my ps2 cable in half and wired a usb connector to both cables and use it on the pi.
                caver01C RiverstormR 2 Replies Last reply Reply Quote 0
                • caver01C
                  caver01 @edmaul69
                  @edmaul69 good point. Mine has a ps2 connector.
                    battlecat @caver01
                    @caver01 OMG I have to read this tonight!
                    • caver01C
                      caver01 @battlecat
                      @battlecat Given some of your posts in past threads, I think you are likely beyond the starting points outlined in the WIKI I wrote. I hope it makes sense, but it is more of a push in the right direction--plenty of detail for some--maybe not enough step-by-step for others.
                      B 2 Replies Last reply Reply Quote 1
                        battlecat @caver01
                        Everything starts somewhere. I am looking forward to reading this no matter what.
                        Once more thank you for starting this up.
                        BC
                        • AndersHPA
                          AndersHP @caver01
                          @caver01 Good work. Would've helped me back in the day.
                          Shouldn't this guide link to your keyboard controllers guide?
                          My Gameboy
                          • RiverstormR
                            Riverstorm
                            Nice guide, well written and nicely laid out. Doing a step-by-step can be grueling but by hitting all the "highlights" then it's easy enough to reference the article when trying to implement something new or ask a question about a section or feature listed.
                            • RiverstormR
                              Riverstorm @edmaul69
                              @edmaul69 said in Setting up a Ipac2:
                              That's a handy piece of information. Last time I tried rigging a cable I couldn't get the shielding grounded properly and it was causing me all kinds of issues.
                              caver01C edmaul69E 2 Replies Last reply Reply Quote 0
                              • caver01C
                                caver01 @Riverstorm
                                @riverstorm my IPAC4 is pretty old, but it came with an adapter cable which is basically just a USB cable that has a PS2 connector at the other end. I didn't realize it was just a matter of getting the pinout correct. I suppose Ultimarc is doing something on the board to detect PS2 or USB? @edmaul69 do you happen to have a pinout of the cable (I guess I could try to map it with an ohm-meter).
                                <EDIT> may have found an adapter example here
                                  @riverstorm @caver01 i used one of the diagrams to wire it up. For the usb end i buy use these usb plugs all the time. I get them from ebay.
                                  • caver01C
                                    caver01 @edmaul69
                                    i buy use these all the time. I get them from ebay.
                                    Me too. I make all of my USB cables from scratch now. Custom lengths are really convenient. I also like to sheath them with paracord.
                                      edmaul69 @caver01
                                      @caver01 i have a lot of paracord in tons of colors. I never tought of that. But yeah folding and tying up cables is a thing of the past. I make everything to exact length now. So much cleaner
                                      • RiverstormR
                                        I had no idea they made USB ends like that! I'll be ordering a few that's really handy. I had never thought of using paracord in that capacity either. Really clever! I have those bracelets attached all over to "go packs" with flash lights, batteries, dynamo crank weather radio's, supplies, etc., etc. Now I have an excuse to buy a few more! ;)
                                          @riverstorm i wear one of the bracelets every day. I have evacuation packs and survival food because you never know when a natural disaster or any other situation might happen. Gotta always be prepared. And i keep a lot of paracord around.
                                          • RiverstormR
                                            Agreed. A little preparedness in the wake of all these catastrophic hurricanes or one bad tornado can make all the difference for sure. At home I am sitting good and when mobile I only carry a few small EDC items on my keychain (mainly a micro light, key size cutting tool & $50) just in case. I've had to use the $50 before and it works as not to big and not to small to break. All 3 items are just a couple ounces. In my car a small waterproof kit and some survival tip cards, signal mirror, whistle, etc. Bigger items in the trunk. Cold is an issue here too as I am close to the Canadian border. Even a few decks of waterproof cards for entertainment. They say half the battle is psychological.
                                            I need get a hold of some good military rations. It was probably about 10 years ago and my younger brother opened an old Vietnam ration meal my uncle gave him while we were sitting around a fire. He ate the whole thing and never did get sick. I am not sure I would have done it but I think it was a testosterone fueled moment while drinking with a bunch of guys. It seemed a good testament to the longevity though.
                                            My wife says I'm weird or what a nerd but in the same breath she basically says shes really glad I do those types of things. :)
                                            A quick question for you. Are you guys cutting old cords when making custom lengths or do you order it in bulk with the ends or something?
                                            edmaul69E caver01C 2 Replies Last reply Reply Quote 0
