    GPi Zero 2 v1.52 & GPi Zero v1.15(Retropie Images for Pi Zero/Zero2 + GPi Case 1 & GPi Case 2W)
    retroflag gpicustom imagecustom theme
    195 Posts 36 Posters 134.6k Views
      joao76
      This image will be updated for the latest released version of retropie ? Or that don't make sence ?
        joao76
        Yesterday i flashed the image to a new sdcard resizing partitions and copy roms. First all working fine then emulationstation crash, im forced shutdown don't have solution. Then the system start ok because the problem i have i'm updating all. The system crash because of new kernel and dtb files i forget this last and big update a few days ago.
        So i have to do all again , and i'm asking this image will be updated or is too much work involved ? Thanks for your help and thanks for your work. If wil be and 1.5 version it's better for me to wait.
          mitu Global Moderator @joao76
          @joao76 said in GPi Zero 2 v1.4 (Retroflag GPi Image for Pi Zero 2 W):
          I think the author mentioned earlier it will not be updated. Set it up and get it working as is. If you update the OS/kernel, then you have to be careful to keep the GPI specific files.
          Sliver XS 1 Reply Last reply Reply Quote 0
          • Sliver XS
            Sliver X @mitu
            I'm probably going to create one last version based on RetroPie 4.8, mainly due to it fixing the hideously bad "Dirty Pipe" vulnerability the v1.4 image I released is susceptible to. I built a 4.8 image for a Zero 2 based console machine I designed recently and overall 4.8 seems a lot more stable than the weeklies I was using before as well.
            To go ahead and get this out of the way now, @joao76
            I am not a RetroPie developer. I have no ties to the RetroPie developers. I've only been using RetroPie for about six months, total. 9 out of 10 questions you keep asking me here and on Reddit are general RetroPie problems that can be resolved by posting a general thread here or elsewhere, or by bothering to read RetroPie's excellent documentation.
            I am not your personal RetroPie/Linux/Computer Usage troubleshooter. Please understand this.
            Sliver XS 1 Reply Last reply Reply Quote 3
            • Sliver XS
              Sliver X @Sliver X
              @Sliver-X
              I've tested and created an archive for v1.5. The first post in this thread has been updated accordingly.
              Sliver XS 1 Reply Last reply Reply Quote 2
              • Sliver XS
                Sliver X @Sliver X
                I've uploaded archives of the four themes I made for this as well as the current versions of the scripts under the "Advanced" menu and a bunch of screenshot-only snaps from my system:
                [Themes]
                https://www.mediafire.com/file/gqagr4v2g49n7w3/GPi_Zero_2_v1.5_Themes.7z/file
                [Scripts]
                https://www.mediafire.com/file/zimeqwfcaz7mhtf/GPi_Zero_2_v1.5_Advanced_Scripts.7z/file
                [Screenshots]
                https://www.mediafire.com/file/zy2p3hmg8zm4d6q/GPi_Zero_2_Snapshots_Only.zip/file (438MB)
                There's 14,173 snapshots for 29 of the configured systems, mostly following the No-Intro naming convention. It's very US-centric, but a bunch of English translated games have snaps as well.
                  jspot
                  i'm having a problem with the dpad using this image i held down the start and up on d pad light flashes . dpad still doesnt work . am i missing something? or is there something to double check?
                    jspot @jspot
                    @jspot updated to 1.5 working now
                      gadg3ts
                      Hi, I've got v1.5 running a GPi and everything seems to work great, except steering in Mario Kart 64. Is there something extra special I should need to do to get that working?
                      Changing axis to hat in the mupen64 InputAutoCfg.ini file doesn't seem to help at all.
                      jstest /dev/input/js0 give the expected output but mupen seems to not be picking up those axes?
                      I'm actually putting the device together for someone elses birthday, so any pointers would be appreciated.
                      Thanks.
                      retropieuser555R Sliver XS 2 Replies Last reply Reply Quote 0
                      • retropieuser555R
                        retropieuser555 @gadg3ts
                        @gadg3ts its using lr-mupenplus right rather than the standalone mupen64plus emulator? In the gpi zero with a pi zero 2w I end up using the libretro version rather than the standalone as the standalone for me is really slow
                        Pi 5 4GB
                        • Sliver XS
                          Sliver X @gadg3ts
                          @gadg3ts
                          Select+X > Controls > Port 1 Controls
                          Set the following:
                          Auto -1 (Key: up) Control Stick Y -
                          Auto +1 (Key: down) Control Stick Y +
                          Auto -0 (Key: left) Control Stick X -
                          Auto +0 (Key: right) Control Stick X +
                          Go back a menu, select "Save Core Remap File" to make it permanent.
                          You can flip it back to the following to restore normal behavior (Remember to save the core override...):
                          Auto -1 (Key: up) Up (digital)
                          Auto +1 (Key: down) Down (digital)
                          Auto -0 (Key: left) Left (digital)
                          Auto +0 (Key: right) Right (digital)
                          Note that this breaks the (Virtual) dpad, so games like Kirby that require it are unplayable unless you start remapping other buttons, which quickly became a case of trying to shoehorn a generalized config for an N64 controller into the GPi case's limited controls... This is impossible, so I left the mappings as default for the N64 core.
                          • retropieuser555R
                            retropieuser555 @Sliver X
                            @Sliver-X I've always wondered this with RetroArch or perhaps the runcommand, if there's anyway of running an if statement checking if the file name contains say "no mercy" and then it'll load a config file for those controls with RetroArch and the mupen64plus core? Just a thought anyway
                            Pi 5 4GB
                              Twippy
                              Hey, I don't own any GPi cases. Could I edit a .txt and get it working via HDMI? Getting a blank screen at the moment.
                              Ta.
                              Jamie
                              • retropieuser555R
                                retropieuser555 @Twippy
                                @Twippy what do you own atm? Would make more sense to just use a regular RetroPie image if you're going for HDMI on a tv usually
                                Pi 5 4GB
                                • Sliver XS
                                  Sliver X @Twippy
                                  @Twippy
                                  Edit /boot/config.txt (This is on the Windows/Any OS Made In The 21st Century accessible partition created on the SD card) and remove the following:
                                  ###gpicase###
                                  boot_delay=3
                                  dtoverlay=audremap,pins_18_19,swap_lr
                                  display_rotate=1
                                  dtoverlay=dpi24
                                  overscan_left=0
                                  overscan_right=0
                                  overscan_top=0
                                  overscan_bottom=0
                                  framebuffer_width=320
                                  framebuffer_height=240
                                  enable_dpi_lcd=1
                                  display_default_lcd=1
                                  dpi_group=2
                                  dpi_mode=87
                                  dpi_output_format=0x6016
                                  #hdmi_timings=320 0 28 18 28 480 0 2 2 4 0 0 0 60 0 32000000 6
                                  hdmi_timings=240 1 38 10 20 320 1 20 4 4 0 0 0 60 0 6400000 1
                                  avoid_safe_mode=1
                                  disable_pvt=1
                                  disable_audio_dither=1
                                  extra_transpose_buffer=2
                                  audio_pwm_mode=2
                                  dtparam=act_led_trigger=default-on
                                  ###gpicase###
                                  When running a Pi Zero 2 on a TV, I also uncomment disable_overscan=1 and add the following lines to config.txt:
                                  overscan_scale=1
                                  hdmi_force_hotplug=1
                                  hdmi_drive=2
                                  I'm not sure if it will prompt you to configure an input if it doesn't detect the GPi Case's controller: If so, just configure as usual, if not, the simplest way to fix this would be to connect a keyboard, hit ALT+F4 to drop to a command prompt and run:
                                  sudo ~/RetroPie-Setup/retropie_setup.sh
                                  Then go to Manage Packages -> Core Packages -> emulationstation -> Configuration or
                                  Configuration / Tools -> emulationstation and choose the option to Clear/Reset Emulation Station's input configuration.
                                  Once it's all up and running, you'll probably want to disable mono sound mixing and get stereo sound back: Connect to your WiFi, enable SSH under the "Advanced Settings" menu and connect to the hostname "gpizero2" with the username pi and the password raspberry (Or just do this with a keyboard like the config reset step). Then run the following:
                                  sudo echo "# default stereo mix" > /etc/asound.conf
                                  Reboot for the changes to take effect.
                                  It would also probably be a good idea to remove the HDMI/LCD detection script and the GPi Case Safe Shutdown python daemon. From a command prompt, run:
                                  sudo nano /etc/rc.local
                                  And remove the following two lines:
                                  sudo /home/pi/gpihdmiout/detect.sh &
                                  sudo python3 /opt/RetroFlag/SafeShutdown.py &
                                  Hit CTRL+X, then Y to save the changes.
                                  Note that there are two minor issues I've found in 1.5 since I released it: lr-picodrive is not set as the default Sega CD emulator and apparently lr-gambatte maps L1/R1 to palette switching functions now that need disabled and saved as a core override so save state/state load work properly for Gameboy games.
                                    SignedUp @Sliver X
                                    @Sliver-X said in GPi Zero 2 v1.5 (Retroflag GPi Image for Pi Zero 2 W):
                                    I have two units: Beside the negative battery terminal on the circuit board is printed "V 11" and the combination to change Dpad modes is Start+Up and Start+Left. The image works on both, but I'm aware there is another revision of the board that uses Select+Up and Select+Up. Is that the combination on yours?
                                    I'm trying to trouble shoot a similar issue where the D-pad doesn't work on a fresh install of v1.5. The GPi case version looks like V11 D, do yours also have the 'D'?
                                    I've tried several SD cards and each time the D-pad doesn't work, although buttons seem to be ok. Switching to DC power rather than batteries fixed a random problem where Emulation Station would crash on first boot.
                                    I haven't tried updating the bootloader on the Zero 2, so might try that after disassembling the GPi and connecting a screen etc.
                                    If anyone has any suggestions I would be very grateful! Recalbox works fine, but definitely prefer your work here @Sliver-X if I can get it working!
                                    obsidianspiderO Sliver XS 2 Replies Last reply Reply Quote 0
                                      obsidianspider @SignedUp
                                      @SignedUp I can confirm that with my V11D case the D-pad does not work with the v1.5 image.
                                      • Sliver XS
                                        Sliver X @SignedUp
                                        @SignedUp
                                        Neither of my units have a D on the PCB.
                                        I configured the image on a unit set to "Axis" mode, which is Select+Left on these particular models. You've tried holding Select+Left or Start+Left for three seconds until the power LED flashes purple? Barring that, for whatever reason, does Select+Up or Start+Up do anything?
                                          SignedUp @Sliver X
                                          This post is deleted!
                                            SignedUp @Sliver X
                                            @Sliver-X thanks for the follow up. I didn't realise there were key combo's that might change some kind of settings, so I've tried a few on this V11D case. I've tried these once the image has booted up to the main horizontal / icon menu. Only two seem to do anything:
                                            • Hold Start + Up on D-pad = red power LED flashes purple momentarily, after about 4 secs of holding buttons. This works pretty reliably, but appears to do nothing other than flash the power LED. D-pad still doesn't work.
                                            • About 1 time in 5-10 attempts, Start + Left on D-pad also flashes the power LED purple, after which the D-pad now works!
                                            So if it isn't working for you, keep trying the holding down of Start + Left on the D-pad, for 4-5 seconds. Repeat and keep your fingers crossed until the Power LED momentarily flashes from Red to Purple and hopefully your D-pad will now work too.
                                            Thanks again @Sliver-X for a great image (that I can now enjoy!) and for keeping track of this thread to trouble shoot this strange issue with different hardware versions of the GPi case.
