    Comunity Case Idea Trade - A Help & Suggest Topic for Cases (Moved)
    16 Posts 4 Posters 4.1k Views
    • L
      LSolrac2
      (Note, moved from the Help section)
      Hello! -first topic- I've noticed there's plenty of Portable Game Cases for the Pi, but most of them are rather 'expensive' ($80+ USD) which is sadly currently beyond me at the moment. I'll be honest I was aiming for a PiGranate or similar. But above the money there's something that bugs me, there's no "modularity" as in you can't take off the Pi and use it outside the case, some cases solider directly to the pi, (Pi Zero is an exception) which ultimately kills that part. It feels that you're stuck with a game console, and not an optional PC. Some very specific cases cut all connectivity with the pi (no usb, hdmi, etc) so I'm posting here , not to complain (that part's done) but to have an open idea and suggest topic on a much easier, more accessible and hopefully more 'free' (freedom) case ideas and have others build on it! Of course, everyone does things their way, most of the time anyway, but might like to share their mods and some might take suggestions.
      Here's my take
      Cardboard for case (for starters) - probably will add a better casing, stronger than plastic, in the meantime I'm using a TV's hard cardboard
      LCD Composite Display (the car ones) - $8-$15
      PiGRRL / SNES Controller Base - $5
      Controller Base Adapters - $7.50-$9
      Speakers - $3 ($1.50 e/a)
      Analog Stick - $5
      Jumper Cables - $2
      7.4v Battery - Good Luck, currently searching, please post what you find
      PowerBoost Porbably of Choice (Please Recommend) - $15-$20 -- Harder Hit
      2x20 Box Header/GPIO Headers (Please Recommend)- $.75/$1.50 - For compiling and easy applications to Pi
      Composite cable - Depends (I got mine with CHIP)
      That's about $47-$60 compare to some cases. Of course, add the Battery and any extra components, keep in mind, this was made with the Pi3 in mind. However, because I am new at this (another motive for making this topic), of course there are some issues such as;
      • No Idea how I'm gonna power up the screen, probably through the PowerBoost
      • Audio comes from composite, probably need an AV>Jack converter or something
      • Still don't know how to assemble this properly, I am using various guides havemercypls
      I am completely open to suggestions for my case, but I hope this example can help others on their quest as well.
      Have you done a case? How was your experience? What was your inspiration?
      Inspired by ::
      https://retropie.org.uk/forum/topic/2217/
      http://www.instructables.com/id/PiGranate-Raspberry-Pi-3-Portable/
      https://learn.adafruit.com/pigrrl-2/trouble-shooting?view=all
      Late Introduction;
      Name's Carlos, Game Designer Graduate, dying to compile to Pi and test some of my games <3
      Projects by Posters
      https://retropie.org.uk/forum/topic/2089/ - moosepr's Pi0 portable console
      https://retropie.org.uk/forum/topic/3241 - bassholio's Wii U Gamepad project
      RESOURCESReally Really Useful stuff
      http://www.shopgoodwill.com/ - Goodwill online (thrift) shop
      http://www.ebay.com/itm/321411385630 - Buttons (OMTEN D3 & others)
      http://www.ebay.com/itm/381374614989 - Jumper Cables for Cheap (120pc MM/MF/FF $3.40)
      http://www.ebay.com/itm/351559246921 - 4.3" Composite LCD -to be tested-
      http://www.ebay.com/itm/152032363921 - RCA-3.5mm converter (amp replacement for headphones)
        Either make a case, out of MDF or Wood. Or do what I did and go to a thrift store or Goodwill. I have had good luck going there to find enclosures. Find something that will work and modify to you hearts content. I made this arcade stick out of an old cassette tape holder
        undefined
        L 1 Reply Last reply Reply Quote 1
        • L
          LSolrac2 @lilbud
          @lilbud said in Comunity Case Idea Trade - A Help & Suggest Topic for Cases (Moved):
          Guessing you picked it up by a local shop or was it by Internet? I'm currently working on finding a way to find a good power source, currently going for a battery charger
          http://www.ebay.com/itm/390845139568?_trksid=p2060353.m1438.l2649&var=660244821954&ssPageName=STRK%3AMEBIDX%3AIT
          lilbudL mooseprM 2 Replies Last reply Reply Quote 0
            lilbud @LSolrac2
            @LSolrac2 Local Goodwill, cost me 50 cents
            • mooseprM
              moosepr @LSolrac2
              @LSolrac2 Good topic!!
              I think its a bit of a balancing act between cost and usability really, especially when you are trying to make something portable.
              A smaller battery may be cheaper, but does 2 hours gameplay sound enough? or a pi3 would be able to play a wider range of games, and play them faster and smoother, but then your going to need a bigger battery, or settle for lower run times.
              if low cost is your goal, then i dont think you will get much lower than my project
              https://retropie.org.uk/forum/topic/2089/yet-another-pi-zero-portable
              Its pretty much the bare minimum you can have for a portable. You could simplify it further by removing the 'uHex' and replace it with a simple switch. That would mean low costs such as:
              pi zero - £4
              ili9341 screen - £6 - http://www.ebay.co.uk/itm/161862594139
              li-po charge/protect board £2 - http://www.ebay.co.uk/itm/301878262849
              buttons OMTEN D3 - £2 - http://www.ebay.co.uk/itm/321411385630
              some wires and stripboard - £0 (i had some lying around from other projects)
              battery - i was lucky on this one, i already had one from an old power bank. It is all down to the runtime you are after. My battery is in the region of 2000-2500mah and that gives a runtime of 10 hours. You could buy a 500mah battery (£3.50 - http://www.ebay.co.uk/itm/401075820588) which will give you 2-3 hours, or you can buy similar batteries with a higher capacity.
              With my project, i have actually powered the pi directly from the battery. this means there is somewhere in the region of 3.7v going into the pi (it ranges from 4.2-3.2v) and it still works!! This is because most of it runs from 3.3v that is converts internally. The 5v is normally only used for USB devices, so if you are not using those, you may not actually need the 5v. (i only have experience on the zero in this matter)
              want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
              • L
                LSolrac2
                @lilbud that's incredibly lucky! (do they have an online store tho? We aren't that lucky in Puerto Rico =u=" )
                @moosepr I did read about it but didn't look at the picture (didn't load back then) and I was impressed then, much more now! I'm going with the Pi3 for PS1+PSP Gaming at highest power, normally I'd use it for almost every other console (minus computers and n64) currently debating really hard how exaclty I'd be powering everything with just a USB Charger over to GPIO but I'm believing that controllers (that don't need any kind of translation, like a joystick) (aka tactile buttons) DON'T use power, am I right?
                Usually we'd be powering 3 things, Pi,Screen,Possibly controller translator. -- I didn't know we could power the Pi with less than 5v, but won't resources be less if done so? (like less CPU and RAM availability)
                Edit: Can we have Video output through normal GPIO? I know the Pi Zero has a composite soldiering place, but it's not through GPIO
                  lilbud @LSolrac2
                  @LSolrac2 Here is a Goodwill auction site. I believe they ship all over the world. You will find something if you are lucky.
                  • L
                    LSolrac2 @lilbud
                    @lilbud Thanks! I've found plenty of goods already (but sadly none that can take a full size pi). Currently seems to be having issues with the registration u.u
                    I did come up with something rather interesting, but I'm certain not everyone is willing to do. I did a bit of search and found that Wii U gamepads can be REALLY Cheap (6+12 GPD as starting bid) Funny how it's basically done, all the maker has to do is hack the Pi In. Please do bring opinions and critics about it. I know it's not a starter route (much less fully DIY which half the fun of all of this) but it's a giant shortcut
                      lilbud @LSolrac2
                      @LSolrac2 I have never seen that done. But good luck
                      • L
                        LSolrac2 @lilbud
                        @lilbud I'm not THAT good at this xD I'm literally brand new to modding and stuff, so while It might be a later project, it was a suggestion for any experienced user. It's all good but it would be quite difficult (at least for me).
                        Don't get me wrong, I do suggest getting a Wii Controller for cheap to build on it, but that might require analog-to-digital conversion.
                        • L
                          LSolrac2
                          Ahhhhhhh @.@ Shortly after replying to Lilbud here I started making a diagram. Hopefully other can use this for reference
                          http://imgur.com/ClvHxpX 0_1470971468220_PiConsole prototype.png
                          For Video, since I haven't found any alternatives, and I'm actually running out of GPIO pins, I'm sticking to composite for now.
                          And for audio, similar case, but I'm thinking of stripping the wire from the composite cables, and connecting it to an amp, which HOPEFULLY I can power using a 3v pin.
                          I found a 4 USB port thing, and hopefuly I can strap it to the bottom as seen. Of course, next to it (in the center) would be the charger for the USB Charger (uses 4 AA-ish, probably LiOn batteries) I chose this way cause it already has a battery meter integrated and has 2 outputs (1a for display, 2a for Pi). Sadly the easy remove part is toned down a bit, as my idea was simply connect the Pi to the GPIO, turn on and enjoy, but I'm sure if you already know that's limited to GPIO and Composite connection. Possibly even USB and HDMI Connections too. Not exactly the smoothest, but at least I can remove the pi and use it in another case.
                          mooseprM 1 Reply Last reply Reply Quote 0
                          • mooseprM
                            moosepr @LSolrac2
                            @LSolrac2
                            not sure if you spotted this yet, but you may want to keep an eye on this guys thread https://retropie.org.uk/forum/topic/3241/my-latest-wii-u-gamepad-work-in-progress
                            The battery pack will probably use 18650 lithium cells, these are pretty much the AA battery of the lithium cell world, but they are a little bigger. The dimensions are actually cleverly used in the name, so they are 18mm in diameter, and 650mm long (this may help you with your planning) You may actually be able to reuse the battery that comes in the wii u controller with something like this https://www.adafruit.com/products/2465. although you would need to check it will be able to provide enough power for the pi 3.
                            If you are short on GPIO, you could make use of the extra usb connections on the pi3, and use some form of usb connection for the controller. You could either wire the buttons to a little board which can convert that to usb, or chop up a usb controller, and use that instead
                              bassholio
                              Hey guys. I'm in the process of installing a pi3 in a Wii gamepad. Here is my progress so far: https://retropie.org.uk/forum/topic/3241
                              • L
                                LSolrac2
                                Welcome aboard bassholio (\OuO/)
                                I've made a small uupdate to the OP with general-use links and poster projects
                                @moosepr The batteries might be extra useful actually! (WIll look and add them to the list), and I thought of something similar but I'm not quite sure how it would work, as I've never really work on boards though. (Of course, I'd be willing to learn.) But as far as I know, the PowerBoosts are quite limited (500 will output .5Amp and 1000 will output 1Amp) and I believe the Pi3 requires 1.5Amp to run fully. Though it's often recommended to use 2Amp just in case, and 2.5Amp if powering USB Devices, which obviously depends on what you'll plug in.
                                • L
                                  LSolrac2
                                  For more on a Wii U gamepad. I've done some research and found plenty of goods.
                                  http://imgur.com/gallery/wmopX < A complete guide
                                  https://www.element14.com/community/thread/48828/l/wii-u-gamepad-raspberry-pi?displayFullThread=true < Concept with a 360 controller and I think a B+
                                  https://www.dropbox.com/s/22tlhbss17rlxil/Plan.pdf?dl=0 < Antother Concept, no design tho
                                  • L
                                    LSolrac2
                                    So, I believe I'll be getting an audio alternative and a 4.3" screen this next week so I'll start building from there. Not a full console, more like an extended Pi Case while I get the other pieces (Controllers, wires, jump boxes, everything else)
                                    the audio alternative is super simple.
                                    Considering most projects output audio into speakers and no option for a 3.5m jack, I was concerned, specially when I would probably power it with only 3 volts (exclusively using GPIO with jumper cables, and Composite to output) so I decided I'd go (for starters) with Headphones. Sure! I'd still need to convert composite to a reliable that. So I found this. http://www.ebay.com/itm/152032363921 It's a cable that can be found cheaper, I just didnt find one that could ship to me </3 so I hope it works marvelously cause I could use this to transfer to an amp normally.
                                    So this pre-alpha build includes the following:
                                    • Carton for prototyping
                                    • 4.3" Composite LCD (hopefully works with 5 volts)
                                    • 10mAh battery (previously owned by me)
                                    • Normal USB Controller
                                    • 3.5mm for Audio
                                    Of course, I'll be building on top of this, but I can't wait to show you guys for any possible inspiration for any ideas
