    8bitdo Pro 2 home button won't work when using xpadneo
    8bitdo pro 2hotkeycontroller8bitdo
    4 Posts 2 Posters 988 Views
    • X
      x_wav
      I can set the home button(the one below the ABXY buttons) to be the hotkey in the controller configuration but it won't work while playing a game. Therefore i am not able to quit the game without rebooting the pi or connecting another controller.
      This happened after i installed xpadneo to fix the issue addressed in this post here.
      Is there any way to fix this while still using XInput or will i have to use a different button as hotkey?
      Pi Model: Pi 4 2gb
      Power Supply used: raspberry pi power supply which came with my pi 400
      RetroPie Version Used : 4.7.20
      Controller used: 8bitdo Pro 2 (over Bluetooth using XInput)
        @x_wav said in 8bitdo Pro 2 home button won't work when using xpadneo:
        Is the button detected as gamepad button or as a key ? Check using jstest if the Home button is detected as a button.
        X 1 Reply Last reply Reply Quote 0
        • X
          x_wav @mitu
          @mitu Thanks for the answer. Nothing changes in jstest when pressing the button.
            mitu Global Moderator @x_wav
            @x_wav This means the button is not registering, so it can't be used.
