    neogeocd lr-neocd problem
    neogeocdlr-neocdbios
    11 Posts 6 Posters 1.9k Views
      KrinaSam
      Previously i used the lr-fbneo-neocd emulator and cue discs and everything was fine. Want to save some disk space i decided to use lr-neocd and chd disc. I read this topic link text
      put the bios in the correct directory, but the games don't start. I have a black screen and back to the emulationstation. Verbosse logging has this effect:
      cat: /home/pi/.attract/romlists/.txt: No such file or directory
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-neocd/libneocd_libretro.so --config /opt/retropie/configs/neogeocd/retroarch.cfg "/home/pi/RetroPie/roms/neogeocd/2020 Super Baseball (World).chd" --verbose --appendconfig /dev/shm/retroarch.cfg
      [INFO] RetroArch 1.9.7 (Git 8373ac6)
      [INFO] Capabilities:  NEON VFPv3 VFPv4
      [INFO] Built: Sep  8 2021
      [INFO] Version: 1.9.7
      [INFO] Git: 8373ac6
      [INFO] [Input]: Found input driver: "x".
      [ERROR] [Core]: Frontend is built for dynamic libretro cores, but path is not set. Cannot continue.
      [ERROR] Fatal error received in: "init_libretro_symbols()"
      [INFO] [Core]: Content ran for a total of: 00 hours, 00 minutes, 00 seconds.
      [INFO] [Core]: Unloading core symbols..
      My bios folder /home/pi/RetroPie/BIOS/neocd/
      000-lo.lo, NEOCD.BIN, ng-lo.rom, uni-bioscd.rom
        barbudreadmon @KrinaSam
        @krinasam said in neogeocd lr-neocd problem:
        Basically, it means the core isn't installed
          KrinaSam @barbudreadmon
          @barbudreadmon I was installing the core from retropie-setup.
          root@retropie:/opt/retropie/libretrocores/lr-neocd# ls
          LICENSE.md  neocd_libretro.so  README.md  retropie.pkg
          DarksaviorD mituM 2 Replies Last reply Reply Quote 0
          • DarksaviorD
            Darksavior @KrinaSam
            @krinasam Did you alter your emulators.cfg? Look at what your setup is trying to execute: libneocd_libretro.so. It's supposed to be neocd_libretro.so
              mitu Global Moderator @KrinaSam
              You may be installing it from the current RetroPie-Setup script, but the runcommand is not the one installed by RetroPie-Setup
              the above line, as @Darksavior hinted, is not installed by RetroPie-Setup.
              Is this an official RetroPie image or a 3rd party image ?
                KrinaSam @Darksavior
                @darksavior said in neogeocd lr-neocd problem:
                @mitu said in neogeocd lr-neocd problem:
                Thanks gentlemen. I have a bug in emulators.cfg. I haven't seen this before. I changed it to neocd_libretro.so and it works now. Installer creates lines in emulators.cfg but in neogeo directory, not in neogeocd directory. Thank you for your help.
                  There's no neogeocd directory in RetroPie, are you using a 3rd party image ?
                    KrinaSam @mitu
                    @mitu Yes. it is a Wolfanoz 1TB img
                    sirhenrythe5thS dankcushionsD 2 Replies Last reply Reply Quote -3
                    • sirhenrythe5thS
                      sirhenrythe5th @KrinaSam
                      @mods: could the name of the 3rd-party-image be deleted from the previous post?
                      There should be no indirect commercial for these &$§#*-in-da-house-images here.
                      RetroRatio: 1.88
                      Started Games beaten: 2,47%
                      Site Rank: 4382/93743 ranked users (TOP 4.76%)
                      Last seen in [The Legend of Zelda: Lost in Time (HACK) [N64], exploring Hyrule at Night]
                        dankcushions Global Moderator @KrinaSam
                        @krinasam I'm sorry, but we don't support third party images: https://retropie.org.uk/forum/topic/3/read-this-first
                        please install official retropie via https://retropie.org.uk/docs/First-Installation/ before seeking support here.
                        @sirhenrythe5th IMO threads like this are a good demonstration of the risks of third party images ;)
                        sirhenrythe5thS 1 Reply Last reply Reply Quote 1
                        • sirhenrythe5thS
                          sirhenrythe5th @dankcushions
                          @dankcushions ok, i see.
                          IMO it would be enough to exchange the title of this image to "a 3rd party-image".
                          Does it really matter if is called Wolfanoz of Foxymouse Mega-Image to realize that those %$#!-images can bring trouble?
                          Edit: i dont want to argue with you!!!! Its just that i hate these prebuilds :/
                          RetroRatio: 1.88
                          • mituM mitu locked this topic on
