    Arcade No Audio
    arcade no audio
    8 Posts 4 Posters 498 Views
      grumpie
      Re: [SOLVED] Troubleshooting Arcade No Audio
      hi, sorry, my english is not that good. i have the same issue. what did he do exactly?
      (i cant reply to the original thread, so i have to create a new one, sry)
        dankcushions Global Moderator
        please start by providing all the info requested in https://retropie.org.uk/forum/topic/3/read-this-first
          grumpie
          sry.
          Pi Model or other hardware: Pi 4b 8gb
          Power Supply used: Labists 3.0A
          RetroPie Version Used 4.7.19
          Built From: eternal lite rpi4
          USB Devices connected: cheap usb keyboard
          Controller used: 8BitDo SN30 Pro USB gamepad
          Error messages received: none
          Verbose log (if relevant):
          Guide used: none
          File: thats the question maybe
          Emulator: i dont know, all arcade roms
          How to replicate the problem: no matter what arcade game i play, there is no sound
            mitu Global Moderator @grumpie
            @grumpie said in Arcade No Audio:
            We don't support 3rd party images, especially the ones loaded with ROMs. Use the image from retropie.org.uk/download if you wish to use this forum for help.
              grumpie
              yes, i know that. im using this image because i had problems with the retropie.org image with retroarch, so i tried another one and this was the smallest i found from a guy, that do it with love, i guess.
              the first thing i did was cleaning the rom folder, cause i got my own roms in my language.
              long time i played those roms on a pc, but on a pi its more comfortable.
                BuZz administrators @grumpie
                @grumpie Doesn't matter. We don't know how that image is configured, ROMs or not. If you switch to our image we can help you
                  grumpie
                  it is very possible that i will do that, i dont like the overload image now.
                  but after four tries with pi imager or the image from this side at earliest next week.
                    grumpie
                    so, im back on the nice n clean image of 4.7.1 but the promlem was still there.
                    i figured out that was an known issue (i guess) with not saving the system volume.
                    i fixed it by switching to 3,5mm jack and back to hdmi audio a few times (in all options i found), sometime the volume could be saved.
                    (i just wrote that to make this thread senseful for some people)
                    have a nice
