    Dithering for 18-bit output?
    crt
    5 Posts 4 Posters 719 Views
    • theanimachineT
      theanimachine
      I'm using a Raspberry Pi 3 to emulate PS1 connected to a CRT TV through VGA666, but I noticed there's banding on FMVs and some scenes. It appears those scenes use a 24-bit color palette, but the hat is bottlenecking the picture. How can I add dithering to the emulators? I tried editing config.txt inside the boot folder, but that only seems to work on EmulationStation, not the RetroArch emulators.
      dankcushionsD lostlessL 2 Replies Last reply Reply Quote 0
        dankcushions Global Moderator @theanimachine
        @theanimachine can you give an example? fmv in PS1 games used pretty brutal compression. it's typical to see constant ugly colour banding on real hardware.
        what did you add?
        theanimachineT 1 Reply Last reply Reply Quote 0
        • quicksilverQ
          quicksilver
          There is a dithering option in the RetroArch quick menu options for pcsxrearmed. I believe it's on by default though.
          • lostlessL
            lostless @theanimachine
            @theanimachine Im sure FMVs on the PS1 were never dithered and were quite compressed. banding was just how they were.
            • theanimachineT
              theanimachine @dankcushions
              @dankcushions
              Not an FMV, but I believe it's a 24-bit color scene. Comparison between a screenshot and the screen. Some of the grays in the photo aren't completely gray.
              what did you add?
              I used hvs_set_dither=0x210
