    SDL Input Joystick for LZDoom (SIJL) for RetroPie
    lzdoom joypadretropiezdoomsijl
    3 Posts 2 Posters 810 Views
    • RapidEdwin08R
      RapidEdwin08
      SDL Input Joystick for LZDoom v3.88b (SIJL) for RetroPie
      https://github.com/RapidEdwin08/sijl
      Add support for SDL Input from Joystick in Menus eliminating the need for a Keyboard.
      Additionally includes Pre-Configured Joypad Mappings + Raspberry Pi specific Tweaks
      NOTE: You must COMPLIE LZDOOM yourself, the Menu Script just helps you load the DIFFs
      This isn't really new, it was started a long time ago under this topic:
      Zdoom and Gampad Fully Working in MENU with NO KEYBOARD
      This is just Updated [rpi_fixes.diff] and slightly tweaked [lzdoom] installer script.
      How To
      1- Use [lzdoom-sijl] Menu driven Script to assist with [sh/diff] files placement.
      2- Compile/Install [lzdoom] from [RetroPie-Setup]:
      0ptional Packages -> Ports -> lzdoom -> INSTALL FROM SOURCE
      When Compiled from Source [lzdoom.ini] will populate your Selected Joy Pad Bindings by Default
      Installation
      Can be ran from retropiemenu:
      wget https://raw.githubusercontent.com/RapidEdwin08/sijl/3.88b/lzdoom-sijl.sh -P ~/RetroPie/retropiemenu
      wget https://raw.githubusercontent.com/RapidEdwin08/sijl/3.88b/lzdoom-sijl.png -P ~/RetroPie/retropiemenu/icons
      0r Can be ran manually from any directory:
      cd ~
      git clone -b 3.88b https://github.com/RapidEdwin08/sijl.git
      sudo chmod 755 ~/sijl/lzdoom-sijl.sh
      cd ~/sijl && ./lzdoom-sijl.sh
      0ptionally you can Add an Entry to retropiemenu [gamelist.xml]:
      	<game>
      		<path>./lzdoom-sijl.sh</path>
      		<name>[lzdoom] SIJL</name>
      		<desc>INSTALL/REMOVE [lzdoom-sijl] for [RetroPie].</desc>
      		<image>/home/pi/RetroPie/retropiemenu/icons/lzdoom-sijl.png</image>
      	</game>
      Changes to lzdoom v3.88b Source before compiling:
      [lzdoom] v3.88b RetroPie-Setup Installer Script:
      local params=("+fullscreen 1 -config $romdir/ports/doom/lzdoom.ini")
      snd_mididevice, -2 (Timidity++)
      mkRomDir "ports/doom/mods"
      00_sbc_tweaks.diff: (0nly Applied to rPi/arm)
      cl_rockettrails, 0
      r_maxparticles, 2500 (Lowered from 4000)
      01_sijl_tweaks.diff:
      CNTRLMNU_OPEN_MAIN = "Open Main Menu";
      use_joystick, true
      03_Preferences.diff:
      am_colorset, 1 (Traditional Doom)
      cl_run, false (Always Run?)
      st_scale, 2
      Crosshair (Cross 1 Green)
      save_dir=$DOOMWADDIR
      disableautosave=2'
      02_JoyMappings_0SFA.diff: (Neutral Axes - Multiple D-Pad Support - 0ut-0f-Box Config for 8+Button JoyPads - togglemap @Joy9)
      const EJoyAxis SDLInputJoystick::DefaultAxes[5] = {JOYAXIS_Yaw, JOYAXIS_Forward, JOYAXIS_None, JOYAXIS_None, JOYAXIS_None};
      Joy1 +jump
      Joy2 +use
      Joy3 +attack
      Joy4 weapnext
      Joy5 +moveleft
      Joy6 +moveright
      Joy7 "toggle cl_run"
      Joy8 menu_main
      Joy9 togglemap
      // D-Pad Bindings Hat
      POV1Up +forward
      POV1Down +back
      POV1Left +left
      POV1Right +right
      Raspberry Pi B, Pi B+, Pi2 B, Pi3 B, Pi3 B+, Pi Zero W, Pi4 (4GB/8GB), Pi5 (8GB/16GB), Pi Zero 2 W, GPi V1, minisforum GK50 / RetroPie 4.8.x
      • RapidEdwin08R
        RapidEdwin08
        I think I might be the only one using this... but either way...
        SIJL has been updated for LZDoom 3.88b.
        Added Utilities for xpad Driver trigmapping patch.
        The 0lder SIJL Branch for LZDoom 3.87c still available if needed.
        • ExarKunIvE
          ExarKunIv @RapidEdwin08
          @RapidEdwin08 I used it before. Worked great.
          Nice to see you updated it to the that version of lzdoom....that I didn't know about. Lol
          I'm too busy working on scripts for RetroPie extras. Lol
