    Get Daphine to work with a joystick other than js0?
    joystickdaphne
    3 Posts 2 Posters 558 Views
      Teh_Lurv
      Power Supply used: Canakit power adapter
      RetroPie Version Used: 4.7.1
      Built From: Official image
      USB Devices connected: GRS SpinnerV2 & GRS Trackball V3 connected to a 12-in-1 board, Dragonrise USB controller encoder, Logitech keyboard receiver, Mayflash Dolphinbar, powered USB 2.0 hub
      Controller used: Dragonrise USB encoder
      Error messages received:
      Verbose log (if relevant):
      Guide used: N/A
      Emulator: Daphne (pre-built binaries)
      Attachment of config files:
      How to replicate the problem:
      Hey everyone, I recently finished putting together by RetroPie cabinet when I noticed the player 1 joystick no longer worked properly with the Daphne emulator. I had previously configured the input file and it was running fine. I quickly determined the cause was due to the player 1 controller being assigned js1 by my Pi.
      Taking a look online for an alternative to juggling all my usb connections yet again, I came across this post that the Daphne Pi emulator port has a -joynum parameter:
      https://retropie.org.uk/forum/topic/21020/daphne-install-dragons-lair-tutorial/16?_=1649199474177
      I gave it a try by setting up an ace.command file in my Space Ace Daphne folder with -joynum 1, however this parameter causes Daphne to quit back to Emulationstation. Trying a different parameter (-silentstart) works fine, so it isn't an issue with the file or formatting.
      Is this parameter still a part of the Pi port of Daphne?
        Teh_Lurv
        Digging further, I noticed the dapinput file I modified had it's changes undone. Not sure how that happened, but re-entering my custom mappings fixed my issue despite my joystick being assigned js1. Perhaps the Daphne documentation is out of date to the current version.
        DirtBagXonD 1 Reply Last reply Reply Quote 0
        • DirtBagXonD
          DirtBagXon @Teh_Lurv
          @Teh_Lurv said in Get Daphine to work with a joystick other than js0?:
          Also take a look here at hypseus, it has improved the Daphne config somewhat. You can assign whatever js is available in the config:
          https://github.com/DirtBagXon/hypseus-singe/blob/master/doc/hypinput.ini
          Also you are able to re-orientate joystick axis:
          https://retropie.org.uk/forum/post/274970
          Hypseus Singe for RetroPie: https://github.com/DirtBagXon/hypseus-singe
          Hypseus Singe Games: https://github.com/DirtBagXon/hypseus_singe_data
          Hypseus Discord: https://discord.gg/dgCsCfmRfJ
