    keep getting stuck on one part of running retropie set-up script on raspbian
    setupstuckpi zero 2
    8 Posts 3 Posters 969 Views
    • genge094G
      genge094
      Pi model: Pi Zero 2 W
      RetroPie-Setup version: 4.8 (44149e3)
      System: rpi3 (armv7l) - Raspbian GNU/Linux 11 (bullseye) - Linux PiGen 5.15.32-v7+ #1538 SMP armv7l GNU/Linux
      Pulled install from retropie website
      USB Devices: Rii x8 keyboard
      WM8960 Waveshare Soundcard
      4INCH HDMI LCD waveshare
      I have tried running through SSH from my PC AND through terminal on the pi itself.
      I have uninstalled, re-written the image and gone through this process multiple times and I just keep getting stuck right here for hours:
      https://pastebin.com/SJMgxqkQ
      always at blendline.lo. Any ideas?? Thanks!
      If it ain't broke, don't fix it!
      S F 2 Replies Last reply Reply Quote 0
        sleve_mcdichael @genge094
        @genge094 said in keep getting stuck on one part of running retropie set-up script on raspbian:
        Unless I am mistaken, this isn't supported. Use 10 (Buster.)
        genge094G 1 Reply Last reply Reply Quote 0
        • genge094G
          genge094 @sleve_mcdichael
          @sleve_mcdichael so legacy OS? should I do Lite?
            @genge094 yes, and yes :)
            (You could do full Desktop edition if you want, but Lite is equivalent to what is distributed on the downloadable images. And the desktop can always be added later too, anyway.)
            • F
              Folly @genge094
              @genge094
              You might want to check this :
              https://retropie.org.uk/forum/topic/31924/could-not-successfully-build-sdl2-on-bullseye
              Fix :
              https://retropie.org.uk/forum/topic/31924/could-not-successfully-build-sdl2-on-bullseye/8
              Fix to fool RetroPie so you can install the binary packages of Buster on Bullseye :
              https://retropie.org.uk/forum/topic/31924/could-not-successfully-build-sdl2-on-bullseye/7
              • genge094G
                genge094 @Folly
                @Folly thanks! I will try this on a second sd card to see which works better!
                • genge094G
                  @sleve_mcdichael thanks! I was able to get it to download on the full desktop OS but it boots into a black screen. I guess I would have to start a new topic for that one though.
                  • F
                    Folly @genge094
                    Can you describe what you exactly did ?
