    Amiga Emulation Problem
    amiga
    3 Posts 3 Posters 416 Views
      MarsBar
      https://retropie.org.uk/docs/Amiga/ < I'm following this, and I have a problem, as I don't have a /home/pi/RetroPie/roms/amiga/ doesn't exist on my micro SD card. I just have a card that has an 'overlays' folder, and a lot of files. I used the 'Raspberry Pi Imager' and selected "RetroPie" to create the disk.
      Can anyone help? I have the BIOS/Kickstart files and some games.
        BuZz administrators @MarsBar
        @MarsBar Sounds like you haven't installed an Amiga emulator yet. Only a selection of the emulators are included by default.
          sleve_mcdichael
          @MarsBar said in Amiga Emulation Problem:
          Sounds like the card is still in your PC, and so you're only able to view the small FAT32-formatted /boot partition. The bulk of the image is on another partition in EXT4 format, which cannot be read by Windows. You'll need to put the card in a Linux system, or put it in your Pi and remote in with SSH/SFTP to view the full filesystem. (There's still no amiga folder, until you install one of the optional Amiga emulators through RetroPie-Setup: https://retropie.org.uk/docs/Updating-RetroPie/#updatinginstalling-individual-packages .)
