    Problem with lr-fuse
    zx spectrum
    10 Posts 3 Posters 3.0k Views
      buzztea
      I have a problem with the lr-fuse emulator on my raspberry pi. I wanted to load a game. When that didn't work, I chose a different setting (48k or Sinclair - ZX Spectrum +3...?) in the Retroarch options. Somehow I must have done something wrong when saving. Actually, I only saved this option for this game...
      Now I can no longer start a game. I get back to the home screen after a few seconds. What can I do ?
      Best regards, buzztea
      • FollyF
        Folly @buzztea
        @buzztea
        You probably saved a game specific config or a game specific core-options file.
        If so, then you have to look here :
        /home/pi/.config/retroarch/config (probably in the fuse directory)
        There will be a filename your_game.cfg or your_game.opt.
        Try to delete that one or these ones and try to load the game again and see if it works.
        If you can't find such a file and loading still doesn't work then it's something else.
          buzztea
          I tried that. I also uninstalled and reinstalled the emulator. Without success.
            Please provide some info about your setup, as asked in https://retropie.org.uk/forum/topic/3/read-this-first.
            Presuming that you have one game where lr-fuse still starts, open the Options menu and - under Manage Core Options reset the options to default.
              buzztea @mitu
              no game starts...:-(
              strange: it works on an older backup.
              • FollyF
                Folly @buzztea
                @buzztea
                • Have you checked your /dev/shm/runcommand.log ?
                  (enable verbose mode when running the game)
                • Have you compared both log's ?
                  buzztea @Folly
                  @Folly
                  very good idea ! I won't be there for a week, will try again afterwards.
                    buzztea
                    Now I have checked the runcommand.log:
                    https://drive.google.com/drive/folders/1O_5wvG6OWtIge-mb-Hw0G5FDa9Pf_I1z?usp=sharing
                    The problem: With the older backup that works, I can't find a fuse folder or a "128-0 rom" in the bios directory. In the other version there is a "fuse" folder. In this there is also a "128-0 rom" But no game can be loaded...?
                      mitu Global Moderator @buzztea
                      @buzztea You've changed the 'Model' core option to a model that requires a BIOS (probably Pentagon/Scorpion ?) and the file is missing.
                      Open /opt/retropie/configs/all/retroarch-core-options.cfg and remove the line that starts with fuse_machine.
                      EDIT: When you change a core option, it is automatically saved when you exit RetroArch. If you wish to change the option just for one game, then you need to:
                      • change the option to the value you want
                      • save the core options for the game
                      • change the option back to the previous/default value
                        buzztea
                        Many thanks for the help. Now it works again! I actually thought that I only made the setting specifically for the game. Probably not...?
