    Module depends on other module.
    scriptmoduledepends
    4 Posts 2 Posters 432 Views
      sleve_mcdichael
      Say I want to make a scriptmodule to install, for example, a Doom mod (IWAD), that relies on an existing lr-prboom installation. How would I write the scriptmodule to check for and install or update if necessary, the other package? I see @fn hasPackage() but it looks like this only works for native Debian packages and not RP's own packages, right?
      Would I just manually query the appropriate retropie.pkg in the PRboom install dir, or is there a slicker way?
        Use rp_isInstalled to check if another scriptmodule is installed.
          sleve_mcdichael @mitu
          @mitu ah thanks, I knew I had seen an rp_something I was just looking in the wrong place (helpers).
          And then if it's not installed, I'd do that with rp_installModule lr-prboom which is the same as rp_callModule lr-prboom _auto_ right?
          Would this all go in the depends_ function of the other module?
          And if I want to make sure it's the latest version anyway, could I just skip the check for rp_isInstalled and just do something like this?
          function depends_mymod() {
              rp_callModule lr-prboom _autoupdate_
            mitu Global Moderator @sleve_mcdichael
            @sleve_mcdichael said in Module depends on other module.:
            And then if it's not installed, I'd do that with rp_installModule lr-prboom which is the same as rp_callModule lr-prboom auto right?
            Yes.
            Yes, you can add it there.
            You could, but that would attempt to install/check update for lr-prboom each time instead of just checking locally that lr-prboom is installed.
