    Audio issue when streaming to twitch
    audiotwitchstreaming
    25 Posts 2 Posters 2.1k Views
    • Y
      yooodt @mitu
      @mitu so I should run the latest update now? Which method shall I use to update?
      Thanks for all your help with this.
        mitu Global Moderator @yooodt
        @yooodt said in Audio issue when streaming to twitch:
        RetroPie doesn't always have the latest version of RetroArch included, updating from RetroPie will get you v1.10.0, the latest - upstream - version is v1.10.3. I didn't test with v1.10.3, but with the latest source code from Github.
        You'll have to wait until RetroPie adds v1.10.3 and then update as normal from RetroPie-Setup to validate you don't have the issue.
        I guess there's one more reason to add v1.10.3 in RetroPie.
        Y 1 Reply Last reply Reply Quote 0
        • Y
          yooodt @mitu
          @mitu Is there a way I can add the latest retroarch without waiting for it to be added to retropie? I can ssh into it so if theres a cmd line way of doing it, great
            @yooodt If you want to test things, then follow the instructions from
            https://retropie.org.uk/forum/topic/33047/updating-retroarch-to-1-10-3.
            • Y
              yooodt @mitu
              @mitu thank you. here goes!!
              Edit - looks a little heavy for me to do right now. I'm going to just run the retropie updater which will put me at 1.10 and patiently wait for the new RA t to be added
              • Y yooodt referenced this topic on
