    Need help with BOOT
    help me pleaseboot problemsd imageretropie issue
    2 Posts 2 Posters 495 Views
      Shnookums13
      Every time I put the Retropie image on my SD card, it tells me that there is only 255 MB of space left on my SD card, and that is nowhere near enough space to put games on. It is a 128 GB card. What do I do to fix this?
        You can't copy your games directly to the SD card from your Windows system. What you're seeing is just the boot partition, there is 2nd Linux partition on the SD card which is not readable by Windows - this is where the actual OS is installed. To transfer your games over use one of the methods supported - see the documentation.
