system-select script not called
Hi there, I have tried to create a script that is triggered on the
system-select
event following the docs.I have created a script
/home/pi/.emulationstation/scripts/system-select/test.sh
:#!/bin/bash echo system select >> /home/pi/test.txt
Which was
chmod +x
'd.This script is not called at all while navigating the retropie menu, selecting systems, and moving between systems (either by returning to the menu or using the quick system selection).
When the script is moved to another event e.g. moved to
scripts/screensaver-start
it works as expected.My system:
Raspberry Pi 4 Model B Rev 1.4
RetroPie 4.8 (RPI 4/400) image
Edit: EmulationStation V2.10.1RP -
Which EmulationStation version are you using ?
@mitu I am using EmulationStation version 2.10.1RP.
Update your EmulationStation package and try again.
