    Amiga games not working in retropi help pls
    emulators not wgameswontload
    11 Posts 5 Posters 2.7k Views
      A Former User
      Hi I wish some help pls as the Amiga games in retropi when I load they won't work.What can I do pls to fix?I tried when I pressed on a game to load while loading I pressed a on the controller so a window with this info pops up:
      Select default emulator for amiga (amiberry)
      Select emulator for rom(amiberry)
      Remove emulator choice for rom
      Select default video for amiberry(CEA-1)
      Select video mode for amiberry+ rom ( )
      Remove video choice for amiberry
      Select framebuffer res for amiberry ( )
      Select framebuffer res for amiberry + ROM ( )
      Launch
      Exit (without launching)
      I tried to change emulators there are only three which are amberry-a1200, amiberry a-500 and last one just amberry ,nothing works....is there something wrong in settings or video I m trying to understand would be glad to have any help pls thanks!!
        Please provide the the info about your setup, as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
        For Amiga emulation, you need to have the BIOS/Kickstart files set-up in the BIOS/amiga folder - see the Amiga and Amiberry documentation pages.
        ? 2 Replies Last reply Reply Quote 0
          A Former User @A Former User
          @biccahobz123 retropi is either 3 b or 3b+, I think is 3b+
          Y 1 Reply Last reply Reply Quote 0
            A Former User @mitu
            @mitu had to open same topic because I had pictures and I could not add in this one and also I wasn't permitted to delete this post that's why.
              A Former User @mitu
              @mitu can u kindly unlock the other one with the pictures that I had successfully uploaded there for the people to help me and instead lock or delete this one pls ? Thankyou
              • Thorr69T
                Thorr69 @A Former User
                @biccahobz123
                You still haven't provided the info requested and you have not addressed the advice that was given.
                Please do the following as mitu asked
                @mitu said in Amiga games not working in retropi help pls:
                And then tell us whether or not you have done this:
                RPi 3b
                Official PSU
                Official RetroPie image
                Pandora's Box 5 controller
                • Y
                  yserra @A Former User
                  @biccahobz123 The pictures on your other post don't help to understand your problem. They are just the starting menu you get when you push a button. It's the normal behavior.
                  Apparently, when you say "retropi is either 3 b or 3b+, I think is 3b+", it seems you don't understand the difference between a hardware (the Raspberry Pi 3B+) and a software (RetroPie). So it's quite difficult to help you, since nobody can be sure you understood the solution that mitu has already given to you: "you need to have the BIOS/Kickstart files set-up in the BIOS/amiga folder".
                  If this answer makes no sense for you, maybe you should watch several youtube tutorials to understand the basics of emulation.
                  • windgW
                    windg
                    You can install the lr-puae2021 amiga emulator, it's more user friendly. But don't forget the bios files, without them the games don't work.
                      A Former User @windg
                      @windg ok thanks
                        A Former User @yserra
                        @yserra it's hard for me to understand but with guidance I succeeded to solve an issue using this forum at least.Where I live there is nobody who is trained to fix retropi unfortunately .thanks anyways
                          @yserra it's 3 b plus I also think but the retro pi I have doesn't have information with it unfortunately not the name of the company,it was gifted to me
