    No sound in games using sound card
    sound cardiqaudiodacalsa
    15 Posts 2 Posters 1.7k Views
    • hhcaseyH
      hhcasey
      I'm trying to install an IQaudio DAC PRO card in my arcade.
      I'm only getting sound when the video snap comes up.
      Once I start the game, there is no sound.
      aplay -L shows the IQaudIODAC is installed.
      I get the error message:
      AudioManager Error - Unable to open SDL audio : ALSA: Couldn't open audio device: No such file or directory
      Anyone know what I might have missed?
      I have done the following based on the card's instructions and the RetroPie Documentation:
      edited the /boot/config.txt with:
      added dtoverlay=iqaudio-dacplus
      disabled onboard sound with #dtparam-audio=on
      enabled hardware interface with dtparam=i2s=on
      I also made the following changes in the EmulationStation sound settings
      audio card set to sysdefault (from aplay -L)
      audio device set to digital (from amixer scontrrols -D sysdefault)
      omx player audio set to ALSA:HW:0,0
      Pi Model: 3B+
      Power Supply: Canakit
      RetroPie Version: 4.8.2
      Built From: Premade from Raspberry Pi Imager
      USB Devices: Ultimarc I-PAC Ultimate I/O
      Sound hat: IQaudio DAC PRO
        If this is not a typo, the correct option is
        #dtparam=audio=on
        Have you tried using default instead of sysdefault ? Does speaker-test (without any parameters) work ?
        Please post the output of aplay -l and aplay -L.
        • hhcaseyH
          hhcasey
          1. Yes, the #dtparam was a typo.
          2. default gives me no sound in snaps or the game.
          3. speaker-test
          speaker-test 1.1.8
          Playback device is default
          Stream parameters are 48000HZ,S16_LE, 1 channels
          Using 16 octaves of pink noise
          Playback open error: -2,No such file or directory
          It generates no sounds.
          1. aplay -1
          pi@retropie:/boot $ aplay -l
          card 0: IQaudIODAC [IQaudIODAC], device 0: IQaudIO DAC HiFi pcm512x-hifi-0 [IQaudIO DAC HiFi pcm512x-hifi-0]
            Subdevices: 1/1
            Subdevice #0: subdevice #0
          1. aplay -L
          pi@retropie:/boot $ aplay -L
          null
              Discard all samples (playback) or generate zero samples (capture)
          default
          output
          sysdefault:CARD=IQaudIODAC
              IQaudIODAC, IQaudIO DAC HiFi pcm512x-hifi-0
              Default Audio Device
          dmix:CARD=IQaudIODAC,DEV=0
              Direct sample mixing device
          dsnoop:CARD=IQaudIODAC,DEV=0
              Direct sample snooping device
          hw:CARD=IQaudIODAC,DEV=0
              Direct hardware device without any conversions
          plughw:CARD=IQaudIODAC,DEV=0
              Hardware device with all software conversions
            Try creating a $HOME/.asoundrc file, with the following contents:
            pcm.!default {
                    type hw
                    card 0
            ctl.!default {
                    type hw
                    card 0
            This will make the sound card be default (not only sysdefault) and should help with games and EmulationStation. speaker-test should also work after this change. In EmulationStation change the Audio Card to default and the Audio Device to Digital.
            • hhcaseyH
              hhcasey
              We're getting closer.
              Here's what was in the .asoundrc file:
              pcm.!default {
              type asym
              playback.pcm {
              type plug
              slave.pcm "output"
              capture.pcm {
              type plug
              slave.pcm "input"
              pcm.output {
              type hw
              card 1
              ctl.!default {
              type hw
              card 1
              I saved this file as a backup and created a new file exactly as you recommended and changed the settings in Emulation Station.
              I get sound on both the snaps and the games but the sound is no better.
              The speaker-test gives me this:
              pi@retropie:~ $ speaker-test
              speaker-test 1.1.8
              Stream parameters are 48000Hz, S16_LE, 1 channels
              Channels count (1) not available for playbacks: Invalid argument
              Setting of hwparams failed: Invalid argument
              and, I'm still getting the error:
              AudioManager Error - Unable to open SDL audio: ALSA: Couldn't open audio device: Device or resource busy
              The new aplay -l and aplay-L looks like this:
              pi@retropie:~ $ aplay -l
              Subdevices: 1/1
              pi@retropie:~ $ aplay -L
              null
              default
              pi@retropie:~ $
                The previous .asoundrc looks more elaborate than what I posted, you can re-use it by changing the index of the default card to 0 :
                pcm.!default {
                type asym
                playback.pcm {
                type plug
                slave.pcm "output"
                capture.pcm {
                type plug
                slave.pcm "input"
                pcm.output {
                type hw
                card 0
                ctl.!default {
                type hw
                card 0
                It may behave better. As for the error appearing in ES, my guess is that the mixer's name (Audio Device) is wrong. Run
                amixer scontents
                and look at the names of the controls. You can also run alsamixer and see what's the name of the mixer that's shown in the upper left corner.
                Make sure that you set Audio Device in EmulationStation to the same value. If you option list for Audio Device doesn't have it, then you can edit $HOME/.emulationstation/es_settings.cfg and add it manually - it should be used by EmulationStation and should get rid of the warnings in the log.
                • hhcaseyH
                  hhcasey
                  I'm not sure how to add the name manually.
                  The name from alsamixer is IQaudIODAC.
                  Here's the es_settings.cfg file I have.
                  <bool name="VideoAudio" value="true" />
                  <bool name="VideoOmxPlayer" value="true" />
                  <int name="MaxVRAM" value="600" />
                  <int name="ScraperResizeHeight" value="0" />
                  <int name="ScraperResizeWidth" value="400" />
                  <int name="ScreenSaverSwapImageTimeout" value="10000" />
                  <int name="ScreenSaverSwapVideoTimeout" value="30000" />
                  <int name="ScreenSaverTime" value="900000" />
                  <int name="SubtitleSize" value="55" />
                  <int name="SystemSleepTime" value="0" />
                  <string name="AudioCard" value="default" />
                  <string name="AudioDevice" value="Digital" />
                  <string name="CollectionSystemsAuto" value="favorites" />
                  <string name="CollectionSystemsCustom" value="2 Player,Rotary Joystick Games,Spinner Games,Superheroes,Trackball Games" />
                  <string name="GamelistViewStyle" value="automatic" />
                  <string name="OMXAudioDev" value="alsa:hw:0,0" />
                  <string name="PowerSaverMode" value="disabled" />
                  <string name="SaveGamelistsMode" value="on exit" />
                  <string name="Scraper" value="TheGamesDB" />
                  <string name="ScreenSaverBehavior" value="slideshow" />
                  <string name="ScreenSaverGameInfo" value="never" />
                  <string name="SlideshowScreenSaverBackgroundAudioFile" value="/home/pi/.emulationstation/slideshow/audio/slideshow_bg.wav" />
                  <string name="SlideshowScreenSaverImageDir" value="/home/pi/.emulationstation/slideshow/image" />
                  <string name="SlideshowScreenSaverImageFilter" value=".png,.jpg" />
                  <string name="StartupSystem" value="" />
                  <string name="SubtitleAlignment" value="left" />
                  <string name="SubtitleFont" value="/usr/share/fonts/truetype/freefont/FreeSans.ttf" />
                  <string name="SubtitleItalicFont" value="/usr/share/fonts/truetype/freefont/FreeSansOblique.ttf" />
                  <string name="ThemeSet" value="carbon" />
                  <string name="TransitionStyle" value="fade" />
                  <string name="UIMode" value="Full" />
                  <string name="UIMode_passkey" value="uuddlrlrba" />
                    @hhcasey said in No sound in games using sound card:
                    If you're at the command line, you can use the nano text editor to edit the file. Just type
                    nano $HOME/.emulationstation/es_settings.cfg
                    and modify the line where AudioDevice is set. Make sure EmulationStation is stopped. You can also edit the file by opening it over file shares from the network, it should be accessible at \\retropie\configs\all\emulationstation.
                    Are you sure this isn't the name of the card ? For instance, the alsamixer output below show the card name is bcm2835 ALSA and the mixer name is PCM.
                    • hhcaseyH
                      hhcasey
                      Getting closer...
                      You're right about the the mixer name. It's "DSP Program".
                      I changed it in the cfg file and in EmulationStation sound settings.
                      I have sound in games but not in the snaps now.
                      I've also picked up a new error message:
                      VolumeControl::getVolume() - Failed to get volume range!
                        mitu Global Moderator @hhcasey
                        @hhcasey Please run the command I mentioned earlier and post the output:
                        amixer scontents
                        • hhcaseyH
                          hhcasey
                          pi@retropie:~ $ amixer scontents
                          Simple mixer control 'DSP Program',0
                            Capabilities: enum
                            Items: 'FIR interpolation with de-emphasis' 'Low latency IIR with de-emphasis'                 'High attenuation with de-emphasis' 'Fixed process flow' 'Ringing-less low late                ncy FIR'
                            Item0: 'FIR interpolation with de-emphasis'
                          Simple mixer control 'Analogue',0
                            Capabilities: pvolume
                            Playback channels: Front Left - Front Right
                            Limits: Playback 0 - 1
                            Mono:
                            Front Left: Playback 1 [100%] [0.00dB]
                            Front Right: Playback 1 [100%] [0.00dB]
                          Simple mixer control 'Analogue Playback Boost',0
                            Capabilities: volume
                            Capture channels: Front Left - Front Right
                            Limits: 0 - 1
                            Front Left: 0 [0%] [0.00dB]
                            Front Right: 0 [0%] [0.00dB]
                          Simple mixer control 'Auto Mute',0
                            Capabilities: pswitch
                            Mono:
                            Front Left: Playback [on]
                            Front Right: Playback [on]
                          Simple mixer control 'Auto Mute Mono',0
                            Capabilities: pswitch pswitch-joined
                            Playback channels: Mono
                            Mono: Playback [on]
                          Simple mixer control 'Auto Mute Time Left',0
                            Capabilities: enum
                            Items: '21ms' '106ms' '213ms' '533ms' '1.07s' '2.13s' '5.33s' '10.66s'
                            Item0: '21ms'
                          Simple mixer control 'Auto Mute Time Right',0
                            Capabilities: enum
                            Item0: '21ms'
                          Simple mixer control 'Clock Missing Period',0
                            Capabilities: enum
                            Items: '1s' '2s' '3s' '4s' '5s' '6s' '7s' '8s'
                            Item0: '1s'
                          Simple mixer control 'Deemphasis',0
                            Mono: Playback [on]
                          Simple mixer control 'Digital',0
                            Capabilities: pvolume pswitch
                            Limits: Playback 0 - 207
                            Mono:
                            Front Left: Playback 207 [100%] [0.00dB] [on]
                            Front Right: Playback 207 [100%] [0.00dB] [on]
                          Simple mixer control 'Max Overclock DAC',0
                            Capabilities: volume volume-joined
                            Capture channels: Mono
                            Limits: 0 - 40
                            Mono: 0 [0%]
                          Simple mixer control 'Max Overclock DSP',0
                            Limits: 0 - 40
                            Mono: 0 [0%]
                          Simple mixer control 'Max Overclock PLL',0
                            Limits: 0 - 20
                            Mono: 0 [0%]
                          Simple mixer control 'Volume Ramp Down Emergency Rate',0
                            Capabilities: enum
                            Items: '1 sample/update' '2 samples/update' '4 samples/update' 'Immediate'
                            Item0: '1 sample/update'
                          Simple mixer control 'Volume Ramp Down Emergency Step',0
                            Capabilities: enum
                            Items: '4dB/step' '2dB/step' '1dB/step' '0.5dB/step'
                            Item0: '4dB/step'
                          Simple mixer control 'Volume Ramp Down Rate',0
                            Capabilities: enum
                          Simple mixer control 'Volume Ramp Down Step',0
                            Capabilities: enum
                            Item0: '1dB/step'
                          Simple mixer control 'Volume Ramp Up Rate',0
                            Capabilities: enum
                          Simple mixer control 'Volume Ramp Up Step',0
                            Capabilities: enum
                            Item0: '1dB/step'
                            Looking at what mixer controls are available, I'd say you need to use Analogue as the mixer name.
                            Exit EmulationStation and update es_settings.cfg and set AudioDevice:
                            <string name="AudioDevice" value="Analogue" />
                            Then see if audio is working in EmulationStation.
                            • hhcaseyH
                              hhcasey
                              That did it. I have sound in the snaps and in the games.
                              I'm still getting this error:
                              If everything is working though, I guess I'll ignore it.
                              I still have laggy sound in Golden Tee 2K and a couple of others.
                              I assume it's the 3B+ struggling.
                              Would overclocking it a help with the lagging?
                                Not for Golden Tee.. Glad you fixed your sound, write down the config files somewhere just in case you need to re-install.
                                • hhcaseyH
                                  hhcasey
                                  I'll backup the chip tomorrow and save the configuration to my desktop PC.
                                  Thanks for the help.
