    8bitdo sn30 pro+ wont pair with retropie
    8bitdoretropie 4.8gpi case 2
    5 Posts 2 Posters 599 Views
      stair_caser
      Hello, I am new to retropie and I just tried connecting my 8bitdo sn30 pro+ to my gpi case 2 running retropie 4.8, but I followed all the instructions (set the switch on the back to B, press start and B together, go into bluetooth in the retro pie settings, and press pair and connect) to no avail. It just said it couldn't find any bluetooth controllers. Can anyone help me with this? I am running on a cm4.
        Stupid question, but does your CM4 have Bluetooth/WiFi ? Some of the CM4 models do not AFAIR.
          stair_caser
          Not a stupid question, @mitu. I got the version without wifi. But I thought all of them came bluetooth. Is this correct?
            mitu Global Moderator @stair_caser
            @stair_caser said in 8bitdo sn30 pro+ wont pair with retropie:
            Is this correct?
            No, the BT and WiFi functionality is provided by the same wireless module. See the official specs - if you have the radio chip then you'd have both WiFi and BT, otherwise none is available.
              stair_caser
              Ok, thank you for letting me know. May be difficult to acquire another cm4, but I will check rpilocater daily from now on for a wireless version.
