    Experiencing input lag on lr-PCSX-ReARMed
    input lag
    9 Posts 4 Posters 2.5k Views
      Glorytonothing
      Using an RPi 3B+, aftermarket 5V 2A power supply, had roms copied over SSH.
      After I performed an update to all packages, i noticed that when I booted up a PSX game, there was about a quarter of a second between when the button was pressed and when action occured on the screen. Is there any way this can be fixed? I'm a noob when it comes to Linux so I don't have a clue. Any help would be greatly appreciated, thank you!
      G dankcushionsD 3 Replies Last reply Reply Quote 0
        Glorytonothing @Glorytonothing
        Edit: I'm also using an Xbox One controller via Bluetooth.
          Can you try updating the pcsx-rearmed core from source and see if the input lag is still present ?
          Also, add some info about what version of RetroPie and how you installed it, as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
            Glorytonothing @mitu
            @mitu My apologies, I forgot about that. I'm using version 4.8.2, made from an official image on a 64GB SD card. And I will try updating from source right now.
              Didn't seem to have very much effect.
              • windgW
                windg
                Do you have the bios files for the pcsxrearmed?
                  Glorytonothing @windg
                  @windg If you mean SPCH-1001.bin, then yes.
                    dankcushions Global Moderator @Glorytonothing
                    @Glorytonothing said in Experiencing input lag on lr-PCSX-ReARMed:
                    could be the issue. do you get any voltage warnings (lightning bolt symbol) in corner of the screen?
                    please also supply the complete information requested by @mitu’s link - including verbose log.
