Building arcade cabinet
I use a raspberry pi 3. I want to make an arcade cabinet. And I install RetroPie for raspberry pi 3. And I didn't find the sonic's room . Where I can download it ? Please help that's a present for my mum and his birthday is the next month.
Sonics room? I'm assuming you mean Sonic Roms?
@Thunderstorm Questions should be posted in the help and support area (your post has been moved). No-one will help you download copyrighted software - it is against the forum rules https://retropie.org.uk/forum/topic/2/forum-rules
Please also put a topic in that describes your problem - not something like "Need help" or "Important". Posting in bold is not going to help you either and will end up earning you a low reputation. I have removed the bold from your post.
If only there was some website where you can search the internet for things... ;)
Google it, should take a couple mins before you find your answer.
@Thunderstorm said in Important:
Get it!
google is your friend.... by your post I am guessing you didn't even look because in just google, i get over 150 thousand hits ...
Seriously, any emulator or rom can be found using a google search....
Its how I found a bunch of fan made games built as roms
... this sure is "important".
