    MAME - USB Mouse works fine, but Aimtrak gun does not
    21 Posts 4 Posters 8.3k Views
      brenthunter2005
      Hello all.
      I've plugged in a normal USB mouse into my RPi and I can successfully run a game that uses a lightgun. I'm using libretro mame 2010.
      However, if I remove the USB mouse, and plug in the Ultimarc Aimtrak gun, the same game does not work with the gun (that should be emulating a mouse).
      My deduction is there is a problem with the Aimtrak gun - so I run a few tests. I can see incoming data using "jstest /dev/input/mouse0" as well as "./advm -device_mouse raw".
      I've checked the configuration of the Aimtrak using its utility and it is configured to emulate a mouse and works absolutely fine on a Windows PC.
      Any advice please?
      Cheers,
      Brent
      • caver01C
        caver01 @brenthunter2005
        @brenthunter2005 It might be important as you test to know that advm is mouse interface testing program for AdvanceMAME, not for any other version of MAME. If you were running AdvanceMAME and configuring it using the .rc files (which is where the device_mouse raw comes into play) you would be on the right track with a valid advm test. But these results don't really apply to lr-mame2010.
        I know my comment doesn't directly help, but you know that advm testing merely proves that AdvanceMAME will see the device.
          brenthunter2005
          Thanks for the info. I used "advm" just to prove to myself that the RPi can get data from the Aimtrak. I wished Mame2010 had something similar. (?)
          • caver01C
            @brenthunter2005 I assume you have seen this thread? @a7mag3ddon had some interesting results when plugging and unplugging devices.
              brenthunter2005
              I have previously confirmed that the Aimtrak can be picked up on /dev/input/mouse0.
              I'm going to perform some further tests later today:
              1. Unplug the Ultimarc IPAC2 (which has support for a Trackball/Spinner) - I noticed that "mouse1" disappeared. AimTrak is still discoverable using "cat /dev/input/mouse0", but still is not recognised by game. I tested with normal Microsoft USB mouse, and all works fine.
              2. Swap around the AimTrak USB ports (it has two usb plugs, one for the gun, and one for the IR receiver) - this didn't make any difference, and AimTrak is still discoverable as /dev/input/mouse0
              3. Start a Linux desktop GUI and check AimTrak works out of the box - Of course I can't test this, because "startx" isn't available. Doh!
              4. Ensure a game in Advmame 1.4 works with the AimTrak - Yes, AimTrak works correctly with Advmame 1.4.
              The goal is to get the AimTrak working with lr-Mame2010, because that is the emulator that is meant to work with a mouse (ie: AimTrak).
                dankcushions Global Moderator
                you could try it in lr-mame2003. it apparently works with the aimtrak gun (as long as that is the only "mouse" that is plugged in)
                  brenthunter2005
                  I still can't get this working. I've edited my post above with the outcomes of my testing.
                  Any other ideas, please?
                    brenthunter2005
                    OK, I think I've got somewhere, kind of....
                    I modified the runcommand to include verbose logging, and discovered some differences in the Mame logging depending if I had the USB Mouse plugged in or the AimTrak device:
                    With the USB mouse plugged in:
                    [udev] Adding device /dev/input/event0 as type ID_INPUT_KEYBOARD.
                    [udev] Adding device /dev/input/event2 as type ID_INPUT_MOUSE.
                    [udev] Adding device /dev/input/mouse0 as type ID_INPUT_MOUSE.
                    Found joypad driver: "udev"
                    With the AimTrak plugged in:
                    [udev] Adding device /dev/input/event4 as type ID_INPUT_MOUSE.
                    [udev] Adding device /dev/input/js1 as type ID_INPUT_MOUSE.
                    [udev]: Plugged pad: Ultimarc Ultimarc (53769:5633) on port #0.
                    Autodetect: 0 profiles found
                    Autodetect: no profiles found for Ulitmarc Ultimarc (53769/5633)
                    [udev]: Pad #0 (/dev/input/event3) supports 0 force feedback effects
                    Found joypad driver: "udev".
                    It appears that the Aimtrak is not being detected exactly the same as the USB Mouse.
                    • caver01C
                      @brenthunter2005 said in MAME - USB Mouse works fine, but Aimtrak gun does not:
                      1. Ensure a game in Advmame 1.4 works with the AimTrak - still trying... , no dice.... I tested with normal Microsoft USB mouse, and all works fine.
                      What did you try in AdvancdMAME 1.4? You already said advm worked. Because it's a mouse device, you need to go through the .rc configuration file and setup the mapping for AdvanceMAME as described in the Spinners and Trackballs wiki page I wrote. Mouse controls don't work if you don't set it up correctly, however, once configured, you can map almost any combination you like, especially knowing you already were successful with advm.
                      B 2 Replies Last reply Reply Quote 0
                        dankcushions Global Moderator @brenthunter2005
                        did you unplug your USB mouse before you plugged in the gun? mame2010 and any other libretro cores should only understand the first mouse (if any)
                          brenthunter2005 @dankcushions
                          @dankcushions Yes, complete power off & on.
                            brenthunter2005 @caver01
                            @caver01 The USB mouse works fine. But when I swap out for the Aimtrak it isn't picked up. I will double-check the configuration.
                              @caver01 AimTrak works correctly with Advmame 1.4. The .rc file is as follows:
                              device_mouse raw
                              device_raw_firstkeyhack no
                              device_raw_mousedev[0] /dev/input/mouse0
                              device_raw_mousedev[1] /dev/input/mouse1
                              device_raw_mousedev[2] /dev/input/mouse2
                              device_raw_mousedev[3] /dev/input/mouse3
                              device_raw_mousetype[0] ps2
                              device_raw_mousetype[1] ps2
                              device_raw_mousetype[2] ps2
                              device_raw_mousetype[3] ps2
                              input_map[p1_dialx] mouse[0,x] mouse[1,x] mouse[2,x]
                              input_map[p1_dialy] mouse[0,y] mouse[1,y] mouse[2,y]
                              input_map[p1_lightgunx] mouse[0,x] mouse[1,x] mouse[2,x]
                              input_map[p1_lightguny] mouse[0,y] mouse[1,y] mouse[2,y]
                              input_map[p1_mousex] mouse[0,x] mouse[1,x] mouse[2,x]
                              input_map[p1_mousey] mouse[0,y] mouse[1,y] mouse[2,y]
                              • markwkiddM
                                markwkidd
                                @brenthunter2005 yesterday, RetroArch added support for light guns in the same category as the AimTrak. I've tested this new functionality with a Dolphinbar/Wiimote and it works great.
                                Since I don't have an Aimtrak gun I'm hoping someone who does will be willing to rebuild RetroArch from source and try out the new feature. Any chance you have one and would be willing to give it a try?
                                  brenthunter2005 @markwkidd
                                  @markwkidd Hello, sorry for my delay. I'll be trying this later this weekend and will let you know how I get on. Thank you!
                                    @markwkidd Sorry mate, I'm not going to be able to test this. I turned on my cabinet this morning and the Aimtrak arcade gun started smoking! I think the solenoid/recoil is broken, so I'm in contact with Ultimarc to investigate further...
                                    markwkiddM 1 Reply Last reply Reply Quote 0
                                    • markwkiddM
                                      markwkidd @brenthunter2005
                                      Oh my. Good luck!
                                        brenthunter2005
                                        Ok, I'm ready to start testing this. Are the updates you refer to now included as part of RetroArch, or will I still need to rebuild from source?
                                        • markwkiddM
                                          Great!
                                          RetroArch 1.6.9 and 1.7.0 should both have the new functionality. Ideally you would use 1.7.0 for the testing because the new lightgun API is still undergoing periodic tweaks.
                                            @markwkidd I feel that I'm started again from scratch with this aimtrak gun. It won't calibrate properly using "gunconf" and everything is upside down (when I move the gun down, the cursor on the screen goes up!).
                                            Let me review my configuration..
                                            caver01C 1 Reply Last reply Reply Quote 1
