    Ps1 star wars jedi power battle doesn't work
    ps1star warsretroplaystation 1bugfix
    2 Posts 2 Posters 654 Views
      JanKruppa007
      Hello,
      I hav a problem with a game star wara jedi power battle on ps1. I install autobleem on ps1 mini classic and only this game doesn't work perfectly. The intro abs start of the game works good, but after 2 min when i play first level of the game, it stops and return me to the autobleem menu. I tried european and usa version (both), but can't solve the problem. Maybe somebody know , how to solve this problem.
      • mituM mitu moved this topic from General Discussion and Gaming on
      • windgW
        windg
        I have read that ps1 mini is using the pcsx-rearmed emulator.
        This emulator had the issue with this game you describe but it get fixed see: https://github.com/libretro/pcsx_rearmed/issues/560. Maybe the version that the system is using is older. I don't know if you can the update the emulator
        You can try to change the Dynamic recompiler to interpreter (slower), if you have this option.
